Mister Fister
Mister Fister New Reader
10/7/16 10:57 a.m.
Your computer is smart enough to limit boost and timing.
z31maniac
z31maniac MegaDork
10/7/16 11:02 a.m.
alfadriver wrote: In reply to z31maniac: I'm sure there is. But if Mitsu didn't at least set that to regular pump fuel, they are fools. This isn't the first or last time that someone will put regular fuel into the Evo. Some of the other times will be totally intentional.
I wouldn't count on it.
On 91 with the stock tune, the BRZ still knocks like a door to door salesman especially in the 2000-4000 range.
I know this from doing data logs through the OBD-II port and watching IAM and knock control.
nderwater
nderwater UltimaDork
10/7/16 11:03 a.m.
Tyler H wrote: In other news, I filled up a boat from a 5 gallon can the other day with one of these. It's just a marble (literally a cat's eye glass marble) loose inside a brass fitting and a piece of hose. Gave it 5 or six shakes and it siphoned the gas. Blew my mind...how did I not know these were a thing, and why don't I own one? Shaker Siphon
Brilliant. I didn't know these existed either, thanks for sharing.
Rusted_Busted_Spit
Rusted_Busted_Spit UberDork
10/7/16 11:38 a.m.
I wouldn't count on it. On 91 with the stock tune, the BRZ still knocks like a door to door salesman especially in the 2000-4000 range. I know this from doing data logs through the OBD-II port and watching IAM and knock control.
Wouldn't the difference be an NA hi comp motor vs a low comp FI motor? I would think staying out of high boost you should be good.
alfadriver
alfadriver MegaDork
10/7/16 11:41 a.m.
All that tells me is that Toyota and Subaru are fools. And for such a "drivers car" they don't really understand their customer all that well. Which is kind of surprising.
One note- for that kind of car, it's possible that an outside firm did the work. That happens all the time. But it's still signed off by the OEM.
This isn't that difficult of technology to implement and calibrate.
z31maniac
z31maniac MegaDork
10/7/16 11:56 a.m.
All that tells me is that Toyota and Subaru are fools. And for such a "drivers car" they don't really understand their customer all that well. Which is kind of surprising. One note- for that kind of car, it's possible that an outside firm did the work. That happens all the time. But it's still signed off by the OEM. This isn't that difficult of technology to implement and calibrate.
You wouldn't think so.
But it seems to be fairly well known in the Subaru community (including the WRX and STi) that many aftermarket tunes, not only make better power, but are much safer because they don't knock like crazy.
With my aftermarket tune on my car (and not even a dyno tune, just an Off the Shelf tune).....the IAM is consistently at 1 and only very, very rarely does it ever have to dial out any timing for knock. Occasionally 1-2° retard for a split second.
keethrax
keethrax Dork
10/7/16 11:58 a.m.
Stock and on 91? Damn.
wearymicrobe
wearymicrobe UltraDork
10/7/16 11:58 a.m.
Stock motor will be fine run a few gallons out of it gentle and then fill it up with some high octane stuff to give your self some piece of mind.
Non stock boost levels or turbo upgrades, drain the tank.
Knurled
Knurled MegaDork
10/7/16 12:20 p.m.
keethrax wrote: Stock and on 91? Damn.
I did a mental double-take when Eric Adams mentioned he had a "91 octane de-tune" on his FR-S.
I wouldn't count on a turbo engine being safe on low octane out of boost. Who knows what Mitsubishi did with cam timing and ignition timing and fuel tuning in order to squeak the max economy out of the little piggy...
z31maniac
z31maniac MegaDork
10/7/16 12:30 p.m.
12.5:1 Compression stock.
And the new Miata is 13:1 !!
alfadriver
alfadriver MegaDork
10/7/16 1:20 p.m.
DI allows some really interesting things.
Fueled by Caffeine
Fueled by Caffeine MegaDork
10/7/16 1:46 p.m.
the car will be fine. My damn 2007 Rav 4 knocks like hell on regular fuel on a light throttle. Apparently this is a design feature, according to Toyota. Also. It's been doing it for 80K miles.. That engine is a honey badger.
codrus
codrus SuperDork
10/7/16 4:12 p.m.
Fueled by Caffeine wrote: the car will be fine. My damn 2007 Rav 4 knocks like hell on regular fuel on a light throttle. Apparently this is a design feature, according to Toyota. Also. It's been doing it for 80K miles.. That engine is a honey badger.
Light throttle knock and WOT-boost knock are very different animals.
The Canadian
The Canadian Reader
10/7/16 5:26 p.m.
found this on an Evo forum: http://www.socalevo.net/threads/151294-Help!!!!-I-Accidently-put-87-oct-in-my-evo!
You need about little more than 3 gallons of 100oct to get it up to 91oct.
Datsun310Guy
Datsun310Guy PowerDork
10/7/16 6:45 p.m.
My sister filled her '73 Beetle with diesel then kept filling with regular to dilute it all out. To this day I'm not sure how that would work but I miss that stupid car.
codrus
codrus SuperDork
10/7/16 6:46 p.m.
Datsun310Guy wrote: My sister filled her '73 Beetle with diesel then kept filling with regular to dilute it all out. To this day I'm not sure how that would work but I miss that stupid car.
Old carbureted engines care a lot less about the details of the fuel than modern cars do. :)
Knurled
Knurled MegaDork
10/7/16 6:50 p.m.
In reply to codrus:
Especially engines with like 6:1 compression.
keethrax
keethrax Dork
10/8/16 5:36 p.m.
12.5:1 Compression stock. And the new Miata is 13:1 !!
Other than the airport, I don't know the closest place to even get higher than 91 from here.
chiodos
chiodos Dork
10/8/16 6:41 p.m.
Just drive slowly out of boost and fill up with fresh premium after you have burned enough to matter. Some say xylene is a hell of an octane booster but ymmv. beware off the shelf octane boosters that "raise octane 14 points!" Thats 1.4 normal points so 87 is now 88.4, not really worth it. If it was me id just burn it lightly, if i was worried id siphon it but modern tanks/filler tubes have anti siphon "valves" so you have to use a smaller hose
BrokenYugo
BrokenYugo UltimaDork
10/8/16 7:15 p.m.
In reply to keethrax:
No idea on unleaded but a Sunoco 110 leaded pump is pretty easy to find.
http://www.sunocoracefuels.com/fuel-finder
maj75
maj75 Reader
10/9/16 10:22 p.m.
Wow, so much panic and hysteria. Thought I was watching the debate...
Stay out of boost, you can do that, right? If so, your car will be fine.
If you are prone to those "forgetfull" moments, drain it now. You will forget to stay off the boost and destroy your engine!
Just kidding, you will be OK.
DaewooOfDeath
DaewooOfDeath SuperDork
10/9/16 10:51 p.m.
87 is extremely corrossive to Evo10 fuel systems, chassis rails, major suspension componenents and brake hardware. You need to get it out of the tank as quickly as possible. I recommend repeated full throttle blasts to redline with lots of left foot braking.
(I am kidding.)
RexSeven
RexSeven UberDork
10/10/16 12:11 a.m.
From one Evo X owner to another, stay out of boost and you should be OK. Even then, the X guzzles petrol like Homer downs Duff and it has a fuel thimble in place of a fuel tank, so it won't take long to empty the 87 octane.
The minimum octane ratings in Japan are higher than in the US, which may explain why the BRZ/86 ECU doesn't account for pisswater Cali 91 and lower-octane fuels. Not that they SHOULDN'T have accounted for this...
DocV
DocV New Reader
10/10/16 4:07 p.m.
I am the original poster. This may have been much ado and paranoia about nothing; I appreciate all the responses. I found 5 gallons of Sunoco 104 octane (“260 GT plus”) in a can. I drove 80 miles off boost and then threw 3 gallons of NASCAR juice in there. Will replace more as I drive. Seems like a winner.
An update for the search engine, Things I think I learned:
  • there is no drain plug on the Evo X tank
  • the anti-siphon things in the filler neck do just that.
  • I did RTFM. Factory manual states that “in case premium grade unleaded gasoline 93 [(MON+RON/2] is not available, 91 can be used; however the performance level is reduced…” If premium grade unleaded gasoline is not available on journey, etc., regular 87 octane can be used temporarily as an emergency measure.”
  • Evo forum community is split on whether the 2015 factory tune is self-destructive or not. discussions on tuning seem to bring out certain cult-like groupthink behaviors. I am not educated enough on turbocharging to know whether this is legitimate or not. One tuner went so far as to offer a free map for the stock components as a kind of public service to prevent destroyed engines (see here: http://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums/723299-fe-evo-too-lean.html)
  • Some people swear by Torco as an octane additive (mostly Corvette/mustang people). Public opinion is that this is likely at least partly "MMT" from looking at the MSDS
  • Lucas octane additive contains the same MMT additive, but in an insignificant amount (may add 1 pt by MON+RON/2 AKI type index?)
  • MMT works to some degree but is hard on plugs and O2 sensors
  • Sunoco high octane stuff is available, and station map is on www.racegas.com
can of magical NASCAR juice (can states 104 octane, "contains toluene"):
pres589
pres589 UberDork
10/10/16 4:16 p.m.
There's a lot of words here and I still don't know if the Evo blew up yet.
WQtZ9vb7hCelJE3wSJO0C8kcwPxiiaz6QNx3vuKPjb04k2vTA58yXyR0kCMdS3eb
