DeadSkunk
DeadSkunk SuperDork
8/19/14 10:24 a.m.
...what could one do with this?
http://annarbor.craigslist.org/cto/4613929485.html
Swank Force One
Swank Force One MegaDork
8/19/14 10:26 a.m.
BMW I6 motor swap, i think.
Giant Purple Snorklewacker
8/19/14 10:26 a.m.
It has 120000 Odomedors. That has to be good for something, right?
pres589
pres589 UltraDork
8/19/14 10:30 a.m.
Part it out? You already took the "run away" option off the table.
bravenrace
bravenrace MegaDork
8/19/14 10:32 a.m.
You could probably walk away from this one and be okay.
BoxheadTim
BoxheadTim UltimaDork
8/19/14 10:37 a.m.
If it indeed suffers from a worn cam, chances are it's been missing a few oil changes. I'd approach with caution or run away...
DeadSkunk
DeadSkunk SuperDork
8/19/14 10:38 a.m.
Would the bell housing match up to some newer GM engines. I'm assuming it's got the Rover version of the old GM aluminum V8.Say,something like the 4.3 V6 or a supercharged 3800.
8/19/14 10:39 a.m.
Coat the world in oil, empty your bank account on British car parts...
Swank Force One
8/19/14 10:40 a.m.
I swear i've seen one of these with the BMW I6 in it, and i remember it damn near bolting up for some strange reason.
RossD
RossD PowerDork
8/19/14 10:47 a.m.
Whatever side the front drive shaft is on, pick the correctly oriented Chevy 350 or Ford 302 with an automatic transmission and transfer case. Have a bastard vehicle with comfy seats.
Basil Exposition
Basil Exposition Dork
8/19/14 11:00 a.m.
Usually the question is "what's the worst that can happen?"
In this case, it should be "what's the best that could happen?"
I'm thinking a lot of blood, sweat, tears, dollars to end up with something not worth much and that continues to fall apart faster than it can be fixed. Walk away.
fidelity101
fidelity101 Dork
8/19/14 11:04 a.m.
treeeeeee fidddddy
DeadSkunk
DeadSkunk SuperDork
8/19/14 11:13 a.m.
In reply to Swank Force One:
Apparently, they were available in other markets with a BMW Diesel, so you may be right.
BoxheadTim
8/19/14 2:20 p.m.
The Range Rover was the one that came with the BMW diesel, these are/were available with Diesel engines but that's a Rover Diesel, not a BMW.
Grizz
Grizz UltraDork
8/19/14 2:23 p.m.
Strip it down for scrap
dculberson
dculberson UberDork
8/19/14 2:33 p.m.
The Range Rover engine bay is pretty short, it's got that little V8 in it and that fills it up pretty well. These are - I think - based on the old Range Rover platform and so I think the BMW I6 would be pretty tight in there. You might be able to do it but it could involve cutting core supports and such.
A better swap would be a Toyota/Lexus v8. Add 120hp and improve fuel economy without adding weight. Yup.
stan
stan UltraDork
8/19/14 2:38 p.m.
DeadSkunk wrote: ...what could one do with this? http://annarbor.craigslist.org/cto/4613929485.html
Just talk about it would be the cheapest option.
beans
beans Dork
8/19/14 3:08 p.m.
Hack it up and make a BBF powered drag car.
Mike
Mike HalfDork
8/19/14 3:11 p.m.
I think there's a Merc diesel swap video on YouTube. "Gutless" was the assessment.
Mr_Clutch42
Mr_Clutch42 HalfDork
8/19/14 3:57 p.m.
I would look at a Mercedes diesel swap and then throw a turbo on it. "Adequate" or "Good" could be the assessment.
NGTD
NGTD SuperDork
8/19/14 5:13 p.m.
RUN AWAY - that's the only sensible option
irish44j
irish44j PowerDork
8/19/14 6:55 p.m.
put some chrome dubs on it and park it in your driveway (NEVER drive it). Your neighbors will think you're a rap star.
mmmESunQ6R5x9wDfAdvY2ACNJcb5BHeqZIVuSQCag7mNE6UKVjs7GVogSVWzpE60
