JG Pasterjak
12/8/23 9:10 a.m.
A turbocharged engine is a double-edged sword. More power is readily available through more boost, but so is more disaster.
So, even if you are vaguely considering turbocharging an engine, plan to at least monitor the other factors that will be affected by the additional air. Most notably, t…
SV reX
SV reX MegaDork
12/8/23 9:29 a.m.
An "available and willing bunghole"?  You guys are a riot.
That's a good article. Thank you.
Msterbee
Msterbee Reader
12/8/23 10:32 a.m.
alfadriver
alfadriver MegaDork
12/8/23 10:33 a.m.
I would encourage people to get a data logging system, so that you are not logging with your eyes. You should be driving.
And even on a dyno, a logging system will show you precisely where the issues are instead of trying to juggle a/f, engine speed, and some load measurement.
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) UltraDork
12/8/23 1:50 p.m.
I like for the ecu to just do all the work for me and kick into failsafe mode if AFR isn't in the appropriate window.
codrus (Forum Supporter)
12/8/23 1:59 p.m.
Agreed, an AFR gauge is at best a warm fuzzy, it's not really useful by itself.  AFR data logged along with RPM, manifold pressure, etc is what you need for tuning.
As far as "failsafe" goes, IME widebands are considerably less reliable than things like fuel pumps and injectors.  I favor tuning the car with the wideband (on the dyno) and then turning off the automatic provisions so that the computer is using the tuned, known-good fuel map.  It can monitor the AFR and turn on a big red warning light if it thinks things are going askew, but it should not silently "fix" the fuel mixture.
alfadriver
alfadriver MegaDork
12/8/23 2:19 p.m.
In reply to codrus (Forum Supporter) :
It would be really nice if MS had an on board provision for a Bosch sensor. Then I would trust it more.
dnospamplease
dnospamplease New Reader
1/10/25 2:11 p.m.
I take issue with the statement, "the stoichiometric ratio, which is the ideal mixture of air and fuel that, when combustion occurs, results in no leftover fuel or its catalyst (oxygen, in this case)."
It should read : In a perfect combustion event, the stoichiometric ratio, which is the ideal mixture of air and fuel that, when combustion occurs, results in no leftover fuel or its catalyst (oxygen, in this case).
A perfect combustion event is rarely obtainable. Look at a combustion event as a singles mixer with 100 males and 100 females. Let's say the mixer is 95% successful; leaving 5 males and 5 females unpaired. If you want to see all the females paired, you must introduce more males to the mixer until that happens.
Same idea with fuel/air mixtures. If you want max power, you want to use all the oxygen in the cylinder (leaving unburned fuel). If you want economy, you want to burn all the fuel (leaving unused oxygen). Richer than max power mixtures provide cooling; working to prevent excess heat, detonation and/or preignition.
FP0Hz0ZrkbMrffWEX9Nx77n5mZSZvRXFKyck7co5pIz8TGnvFgEkRgxHT1618mKp
