pilotbraden
pilotbraden Dork
8/13/12 12:06 p.m.
Last weekend I drove by a Mazda Protoge with it's hood up in a parking lot. 30 minutes later it is still there with 3 people standing around it looking befuddled. I have some Mazda parts less than a mile away so I stop to see if they need help. The rubber line from the clutch master cylinder to the slave cylinder had broken. These guys had made a good repair using a piece of brass tubing inside the rubber hose secured with hose clamps. They were having a hard time bleeding the line. My mighty-vac vacuum pump is loaned out so I could not loan that to them. As I drove off I had an idea. If I put a hose on the bleeder and put the other end on a vacuum port on the intake it should bleed. I stopped at the hardware picked up 4' of clear vinyl tubing. I went back and explained what I had in mind. We hooked up the tubing, fired up the engine and the fluid started flowing. In under a minute the bubbles and nasty looking fluid were gone. It worked very well. I might start bleeding my brakes this way. Are there any disadvantages to this method?
DrBoost
DrBoost UberDork
8/13/12 12:08 p.m.
Your screen name should be pilotMacGyver.
Nice thinking outside the bun.
Tyler H
Tyler H Dork
8/13/12 12:26 p.m.
Why isn't this more common? Especially with one of the in-line resevoirs (like from my broken Mity-vac,) so you don't suck flud into the engine. I may have to try this.
Kenny_McCormic
Kenny_McCormic Reader
8/13/12 1:12 p.m.
Brake fluid eats a lot of things you wouldn't expect it to, might not play well with the intake valve stem seals.
Tyler H
Tyler H Dork
8/13/12 1:33 p.m.
Kenny_McCormic wrote: Brake fluid eats a lot of things you wouldn't expect it to, might not play well with the intake valve stem seals.
That's why I think an in-line resevoir would be critical.
donalson
donalson PowerDork
8/13/12 1:34 p.m.
Tyler H wrote: Why isn't this more common? Especially with one of the in-line resevoirs (like from my broken Mity-vac,) so you don't suck flud into the engine. I may have to try this.
exactly... my HF pump was a POS and died quickly... but still have that inline bottle... been using it as a large 1 man bleeder bottle... but I may have to try it out like this...
pilotbraden
pilotbraden Dork
8/13/12 1:37 p.m.
I did tell the guys that I would run some carburetor cleaner through the same vacuum port, just in case something didn't like brake fluid.
dlmater
dlmater Reader
8/13/12 1:39 p.m.
I have no idea how I remember this, but some guy patented this idea many years ago. I don't ever remember seeing a commercially available unit for sale though.
Engine Vacuum Brake Bleeder
lwgQxu8214UeZZmNmtyizGsgucZpAyjBQRLYjicRsMeDwUL0xenJeLZZt2xK94h2
