AWSX1686
AWSX1686 Dork
4/6/18 7:04 p.m.
I need a larger coolant expansion tank for the challenge car. I also don't have too much room for one, so I suspect it will need to be custom. Also trying to do it on the cheap, naturally as it is for the challenge build. I have a MIG welder, and I'm getting more competent with it, but don't have aluminum capabilities.
Ideas.....? and go!
Patrick
Patrick MegaDork
4/6/18 7:08 p.m.
Junkyard and tape measure
AWSX1686
AWSX1686 Dork
4/6/18 7:08 p.m.
My first idea was to find a suitability sized fire extinguisher and weld a radiator cap piece to the top.
Something along these lines, though this is an overflow more than an expansion tank.
AWSX1686
AWSX1686 Dork
4/6/18 7:09 p.m.
Another one, ish...
Trackmouse
Trackmouse UltraDork
4/6/18 10:11 p.m.
On my 1uzfe swap, the engine normally has an expansion. But there “whas no whey”.
So I relocated, and reused my factory overfloweth tank. Reduce, reuse, recycle. The hippy way.
Fyi- I’m at the bottom of a Spanish coffee, so... yeah.
GIRTHQUAKE
GIRTHQUAKE New Reader
4/7/18 9:26 a.m.
I've been saving a 1.75 L Jack Daniel's bottle for a coolant overflow bottle for years, but you really wanna be careful using glass since thermal shock can crack it easily. So go with Patrick's suggestion- tape measure and a junk yard. Allegedly Ford Powerstroke coolant overflow tanks are stout and made of real thick plastic.
iMCK0zjClQPDbVp8TQM4SxrbGlGhdfx6PJjyXY9DxPilCyvIgn3Zu6IHBrzsgRKP
