fastbmw
fastbmw New Reader
1/18/10 11:48 p.m.
Hey e30 guys,
What would be a good alignment setting for a street driven e30? (325i H&R sports w/Billy shocks.) I'm looking for a slightly aggresive set-up compared to the stock setting. Currently the car has no problems with tire wear.
Thanks, Alex
speedblind
speedblind Reader
1/19/10 10:49 a.m.
Depends on what you have on the car. Stock, you can only adjust toe on E30s. If you have camber/caster plates up front and alignment correction in the rear, you can experiment.
On my old car I had GC SpecE30 front camber plates and the IE weld-in kit.
I ended up with (or close to):
F. Camber -3.0-3.5
F. Toe Zero
F. Caster Max
R. Camber -2.0-2.5 (exactly one degree difference, front to rear)
R. Toe 1/8" in
speedblind
speedblind Reader
1/19/10 10:50 a.m.
I should add that I didn't own the car long enough to really experiment with alignment settings, so take my setup as a baseline. The car drove fine with the above.
z31maniac
z31maniac Dork
1/19/10 10:53 a.m.
No adjustment out back for me at the moment, but on both cars for the street I run.
Zero toe -2.5 camber as much caster as I can get
GWALls67eZInHbWXRWLZA4GDdRXEJxHA1TMnwCWwPiHf2OVwNNYXtHD7ChxxGCl0
