mlwebb
mlwebb New Reader
12/16/17 8:44 p.m.
I just need enough to make the turn, on the front edge of the front wheel well. Probably would have been fine, but I moved the body back half an inch on the frame because I needed it elsewhere. Tires are the same diameter as original, but considerably wider.  Wheel well has a half inch 90 deg flange in front (the rest folded in some time ago). Paint is 2 yrs old, fender metal 50 yrs old and relatively thick.
So can I roll the flange in, and then the flare out a little without messing the paint up? If so, what do I need in terms of tools and technique?
Other than the front edge when turning, fit is fine.  The back is a little snug, but well located, I think it will be fine.
So do I have a chance of rolling the front wheelwell edge without messing up the paint? If so, what do I need to do it. My temporary spray booth is long gone, so while touch up is possible, it would be a pain, and I would have to wait til the weather warms up (no heat in shop).
Michael
Dr. Hess
Dr. Hess MegaDork
12/16/17 8:59 p.m.
How lucky do you feel?
Cheap:  Heat the paint SOME with a heat gun.  Put a baseball bat between the tire and the fender.  Have your helper VERY SLOWLY roll the car as you control the baseball bat.
More Expensive:  Buy, rent, borrow one of those professional roller systems that you put on the car and roll the fender with.
Knurled.
Knurled. MegaDork
12/16/17 9:01 p.m.
Be gradual.
I ended up rolling the fenders out a couple inches on the RX-7 to clear 225/50-15s.  Paint never cracked.  I used a baseball bat and patience.
Rust did start forming after I cut the fenders after i moved the axle centerline forward, tho.
Vigo UltimaDork
12/16/17 10:06 p.m.
The tools are cheap enough now that i would just buy one on ebay. Maybe sell it on CL after you have actually driven the car and run it through its full range of steering + compression travel to verify that it's actually fixed.
Be gradual and use heat to keep the paint from cracking are the big things.
Dr. Hess
Dr. Hess MegaDork
12/17/17 7:46 a.m.
I had no idea those things were now $35 on ebay.  A baseball bat will be a significant percentage of that.  If I had to do that today, I would just get the ebay version.  Good thing I only deal with fiberglass cars now.
mlwebb
mlwebb New Reader
12/17/17 8:31 a.m.
I had no idea either, ordered one at 36.95 shipped.
wheelsmithy
wheelsmithy Dork
12/17/17 10:13 a.m.
I have nothing to add, other than NICE DATSUN !, and A cheap fender roller is now on my want list.
But yes, delicately heat, and gently roll.
Mndsm
Mndsm MegaDork
12/17/17 10:37 a.m.
One word- heat. The hotter you can get it without bubblingthe paint, the better. Go slow, go evenly.
akylekoz
akylekoz HalfDork
12/18/17 5:29 a.m.
My 25 year old paint cracked, not enough heat and I went too fast.  Rolling on a hot day would help too, it was probably 45 degrees when I did mine.
84FSP
84FSP Dork
12/18/17 7:22 a.m.
Heat and seal the inner fender with something afterward.  Fantastic that the right tool got cheap.  A second a set of hands and copious heat carefully applied.
Tyler H
Tyler H UltraDork
12/18/17 7:59 a.m.
I bought the Eastwood roller and it worked on an E46, so it's pretty stout.  I'd venture a guess that putting some grease on the threads and running it through it's range of motion a few times would be a good investment on the <$40 version, which looks identical to the Eastwood kit.
Fueled by Caffeine
Fueled by Caffeine MegaDork
12/18/17 8:36 a.m.
How to roll fenders.
1. Cut fenders with Sawzall
2. Install flares(preferably box flares)
3. Profit!!!!!!!!!!
mlwebb
mlwebb New Reader
12/18/17 11:55 a.m.
Sounds like a point and shoot thermometer would be useful.
Re flares, the rear is usually the limiting factor, with a 195 tight on a stock fender.  I spread the back when I was doing bodywork, here is a 235/50/15 R888R on a 9" wheel. The front 225's will just stick out a little.
Michael
Jaynen
Jaynen SuperDork
12/18/17 12:26 p.m.
I ended up buying a roller, think I paid 60 bucks.
Mndsm
Mndsm MegaDork
12/18/17 4:34 p.m.
It always kills me how cheap these are now. I spent like 350 bucks on my Eastwood many moons ago. It is now bent and stolen(so....presumably still bent) but I made a decent wad with it . Did loads of cars
DMJ7fktGzvxMTiRVNxbZhsBCNaEpXTAZBHJ4cjGqpiwXza7wFe5uVEDj5a9iZjdh
