oldeskewltoy
oldeskewltoy UltraDork
4/1/16 10:42 a.m.
to the story on the piston going through the hood.... not sure how the piston came through the head first...?????
One thing that hasn't been discussed is bearing clearances... USE the FSM, it is your friend. I typically use the middle of the spec for main bearings (+ or - .0005"). When it comes to rod bearings I usually run clearances just loose of the middle of the spec.
Use new rod bolts(came with rods) Check with Eagle for their torque spec for those rods.
Knurled
Knurled MegaDork
4/1/16 11:12 a.m.
oldeskewltoy wrote: to the story on the piston going through the hood.... not sure how the piston came through the head first...?????
probably had 30 pounds of boost at idle because the wastegate was turned up too high... then it caught posi and BAM, piston through the hood. see it all the time.
dansxr2
dansxr2 Dork
4/6/16 3:03 p.m.
 photo IMG_20160405_213629623_zps7jir11ck.jpg Dropping off in the morning. Having the block cleaned, crank and Flywheel balanced, crank checked and polished, bores checked and honed. Looking forward to reassembly!
0npM4LW4DiLxL20QleA5xchydsxbaXV60lNNmKtrCcPmdcTKlrkJPOwtxTOyMzPC
