Dootz
Dootz Reader
10/28/19 4:37 a.m.
Have an '06 Pathfinder base model with the 16s - the tires are getting bald, and I'm trying to sell it pretty soon (otherwise I'd throw a set of 17s on it). The tires feel like they're way too wide for the wheel, and way too tall - getting a lot of excess body roll (could be the suspension, but the tires aren't helping right now). Should I stick with the OEM tire size, or go down? Feel like the 235/60s would aid tremendously with the handling, and the capacity/load of the tires shouldn't be compromised with the Kumho Crugen HT51s that I'm looking to throw on (XL load range).
akylekoz
akylekoz SuperDork
10/28/19 5:56 a.m.
It may look funny with lots of gap between the fender and tire.  I don't think that is the factory size tire and maybe just not enough tire for the truck.  Our shop Frontier Crew takes a 265/70/16 my Pathfinder takes a 265/60/18 these are stock sizes.
I'm going up to a 275/65/18 on mine so the tires don't look so small.
Dootz
Dootz Reader
10/28/19 8:32 a.m.
I'm okay with the gap, functionality supersedes appearance here. Not enough tire? The 245s are already looking too wide for the wheel - unless that's normal for trucks/bigger SUVs.
10/28/19 8:38 a.m.
235-60s give you a sidewall height of 141mm.
245-75s give a sidewall height of 183mm.
That's a difference of 42mm or 1.653 inches (1  5/8").   Watch out for pot holes.
Vigo MegaDork
10/28/19 10:43 a.m.
I think it will act better and look worse. Whether that's worth it is up to you.
iceracer
iceracer UltimaDork
10/28/19 3:04 p.m.
about 4" smaller in diameter assuming you are using the same wheel
ProDarwin
ProDarwin UltimaDork
10/28/19 3:27 p.m.
This seems like a terrible idea if you are trying to sell it.
z31maniac
z31maniac MegaDork
10/28/19 4:12 p.m.
I agree with this. If I went to look at what should be an average car, with the wrong size tires on it, I would immediately be suspect of everything and likely walk away.
QFuOEUeSIRpRSqhlg2MUyKzRVC8R6333PjTjplFn7MQiiyd5plXkfO4jhAHIfYri
