accordionfolder
accordionfolder UltraDork
2/8/23 5:43 p.m.
Can someone help your local goober out, I've poked at this a bit, but don't want to break it.... How do I refill this? And what oil?
JMcD
JMcD New Reader
2/8/23 7:10 p.m.
Mine looks a bit different but has a hex headed screw in the same spot as the yellow knob that I unscrew and add oil.
codrus (Forum Supporter)
2/8/23 7:33 p.m.
I have one like that for the air-powered bridge jacks on my lift and yeah, it has a screw like JMcD's does.  It's kind of a PITA because it's a super narrow fill tube and the oil is thick enough that the air doesn't want to come out to make room for it.  I usually wind up using a teeny tiny straw (I steal one off the side of a can of brake cleaner) to make a passage for the air to get out.
I've always just used the red air tool oil that they sell at the parts store.  The current bottle is over a decade old, it doesn't take much. :)
Slippery
Slippery PowerDork
2/8/23 7:39 p.m.
The bottom glass should unscrew in the direction of the arrow.
Might need to push up a little while you turn.
accordionfolder
2/8/23 7:59 p.m.
Uh oh - conflicting advice!  I tried to unscrew the glass and it really didn't want to move, which is why I asked here, hahaha. Are we sure? I couldn't decide if that was the direction of airflow or the direction to screw.
Slippery
Slippery PowerDork
2/8/23 8:02 p.m.
I dont want to cause you to break your stuff, but the ones in CNC machines unscrew from the bottom. They are tricky though.
Did you get a plastic wrench with it that fits those "ribs" on the bowl?
Might be smart to ignore my advise, lol.
Slippery
Slippery PowerDork
2/8/23 8:07 p.m.
Any idea what brand that is? I tried looking up that SBC1656 number but had no luck.
accordionfolder
2/8/23 8:31 p.m.
It's a Derek Weaver tire changer, let me see if I can find anything in the manual
EvanB
EvanB MegaDork
2/8/23 8:34 p.m.
The derek weaver manual I found shows unscrewing the reservoir to fill.
accordionfolder
2/8/23 8:49 p.m.
GLTC rubber going on. Let me see if I can get it taken off...
accordionfolder
2/8/23 11:04 p.m.
Well, you guys were right! It took a lot of force to break it loose, which was what had me worried I was doing something wrong in the first place. Thanks everybody!
Cactus
Cactus HalfDork
2/8/23 11:11 p.m.
Mine broke ages ago so I just spritz some air tool oil in the coupler every time I think about it (which is maybe every other time I use it). I should probably just go buy a harbor freight dryer/oiler.
Slippery
Slippery PowerDork
2/9/23 3:51 p.m.
Cool! I need some tires flipped, wish you were closer :)
accordionfolder
2/9/23 4:06 p.m.
In reply to Slippery :
Ha! Yeah, I've flipped so many tires with this machine, worth it's weight in gold if you're a track rat/club racer!
Thanks for the help!
hc6n240Kl0G077cHSEseKxNrBRLV0DOw55WHm1k3Qo5NZDuHzuCPgmZ8d18TL8HQ
