oldeskewltoy
oldeskewltoy SuperDork
1/5/15 6:05 p.m.
I'm seeking some wisdom on the Miata BP-Z3 cylinder head(2001-2005). I have a potential client with a BP-Z3 head that has absorbed some damaged - see highlighted areas
My concern is milling this to get to good metal, but because this is VVT, is there a way to compensate cam timing/setting for the lost material?
Or does this require a weld up... or is this junk??
What say you........??
echoechoecho
echoechoecho New Reader
1/5/15 7:03 p.m.
How much do you have to shave to get to clean metal? This is the equation to find how much degrees retard you have after shaving/decking. 2*arcsin(shave amount/cam gear radius) = degrees retard
x3bdPZB53FhEq01IBEeluF0eEAxybGFVi0vS5egdDvSP3LntzdHb1fjCCiclFH4Z
