2 3 4
12/31/21 8:55 a.m.
No, no, I'm not a canoe.  I've been looking to replace the 914 with something more sedan-ish (that seat gets closer to the ground every summer) and I keep going back to the Amazons.  Researching engine specs etc, this old thread popped up; good info guys.  There's a 911 in my garage that I may end up the next custodian of, but it's nor me.  If chosen I will probably flip it.  I also like the Mercedes W-180 but not as much as the 122s.  Will any other transmissions bolt up to the B-18 block?
paddygarcia
paddygarcia Reader
12/31/21 9:30 a.m.
In reply to 914Driver :
If the M40 isn't enough gears the M41 overdrive is a direct swap.
T-5 and T-9 are the easyish non-Volvo options. These and other modern options would require a 140/240 trans hump (still available from Volvo AFAIK).
What's the goal for a different trans?
volvoclearinghouse
volvoclearinghouse PowerDork
12/31/21 9:38 a.m.
T9s are a bit thin on the ground over here, but T5s are a pretty well-documented swap. I'm not 100 pct sure, but an automatic car would have a larger trans hump that might fit the larger transmission.
I wasn't a huge fan of the electric OD's until I bought a 66 Jag with one. I'd just become accustomed to the engine singing along at 4000 rpm on the highway. But with the overdrive engaged, the big 6 in the jag just bubbles happily.  Different cars, different engines, different purposes.
12/31/21 3:12 p.m.
Won't be doing big highway trips with it, at least not enough to do damage.  Automatic vs happy at highway?  Sorry, gotta be a stick.
I've seen a Ranger V-6 auto in a 544, but that strikes me as nose heavy.  Call me old or a dumbass but an automatic is like cream in your coffee or condoms, gets the job done but just takes all the joy out of it!
Kreb (Forum Supporter)
12/31/21 3:40 p.m.
Call me a philistine, but a Ford Ranger-spec Duratec 2.3 with the 5 speed should be wonderful in that car. Lighter, inexpensive and more powerful.
paddygarcia
paddygarcia Reader
12/31/21 3:53 p.m.
I see - the car in the link is a 4 speed but you're asking drives haft. The BW35 auto does suck all the fun out.
M40 and associated clutch and driveshaft is a bolt-in to an auto car. M41 same but should be able to use the auto driveshaft.
volvoclearinghouse
1/1/22 12:26 a.m.
My point was that an automatic 122 would have a larger trans hump, so swapping to an OD stick shift might be easier. The pedal cluster is an easy swap.
2 3 4
jTBNpZhMyhULppxLb4UN21FXbUUKs98bQx6ySHynCOkgrhECbtOg1OwOVeuehId4
