SkinnyG
SkinnyG SuperDork
5/3/18 9:16 p.m.
Factory cars are usually merely spot-welded, which leaves potential gaps everywhere.  Easy button is to seam seal every crack to keep moisture out.
Dusterbd13
Dusterbd13 MegaDork
5/3/18 9:18 p.m.
In reply to maschinenbau :
Generally to keep water out of places that are impossible to rust proof otherwise. But in this case, both.
Gtx: thanks! Im still working on my waxer streak. Haven't quite gotten rid of it yet.....
maschinenbau
maschinenbau Dork
5/4/18 7:16 a.m.
So if a chassis is simple enough and was seam welded everywhere and painted appropriately, theoretically it shouldn't need any seam sealer other than to smooth over nasty fab work? Asking for a friend...
Dusterbd13
Dusterbd13 MegaDork
5/4/18 7:19 a.m.
Theoretically. However, ive never seen a water tight seam weld. Thats why the challenge car had the money spent on the seam sealer, as it definitely has a life after the challenge.
paranoid_android
paranoid_android UltraDork
1/20/19 8:49 p.m.
Not a canoe!  Just me checking in for any other input on this topic.
This week I plan to prime, seam seal and eventually paint a wheel well before suspension starts going back in.  I’m as yet undecided on what sealer to use...
Dusterbd13- did you end up painting over the seam sealer you put on?  How did that go?
Dusterbd13-michael
Dusterbd13-michael MegaDork
1/21/19 12:14 p.m.
I did!
Used a cut down paint brush and a rubber gloved finger to spread, and then painted right over with tractor paint and rustoleum.
maschinenbau
maschinenbau Dork
1/21/19 12:22 p.m.
I recently did some seams too. I bought a quart of "Speedokote" on Amazon for like $25 and some cheap rubber spatulas to spread it around. I think it looks pretty good after painting over. The 1 quart should do every seam I want to cover on this car.
paranoid_android
1/21/19 3:31 p.m.
So no special magic involved?  Let it dry completely, make sure it’s clean and then paint it?
I think I can handle that!
Dusterbd13-michael
1/21/19 3:59 p.m.
Yes. Especially the dry completely. Twice as long as the can called for. And make sure to buy the paintable seam sealer
SkinnyG
SkinnyG UltraDork
1/21/19 7:01 p.m.
The caulking-gun style tubes are easier and neater than the tin can style.  I did a lot of the V8 Firefly with the can and brushes, but the tubes are way worth it (though more expensive per volume).
lcIXBhfuXKVLShwS78cAqw579VaL3x04lZ1D7QXfa4xg547fn5PJkAwzlVFrNdIp
