LuxInterior
LuxInterior Reader
2/20/15 10:51 a.m.
I'm curious: When swapping an alternate fuel injected engine into an early Miata, how hard is it to get working gauges on the factory cluster? (tach, temp & oil pressure etc). Engine would be controlled with Megasquirt.
Swank Force One
Swank Force One MegaDork
2/20/15 11:03 a.m.
The ECU outputs those signals, so Megasquirt would be taking care of it.
Answer: Easy.
BoxheadTim
BoxheadTim UltimaDork
2/20/15 11:05 a.m.
Actually the oil pressure gauge on an NA is directly hooked up to the sender so all you need is to swap over the sender unit to the later engine.
PwKaFH6OTnUXFjQzhTIhuOUp9q2rvEkbK6aWS2HgdREh6GCtMKcYfTE3ez1vWOTh
