Gimp (Forum Supporter)
Gimp (Forum Supporter) UltraDork
9/15/23 5:00 p.m.
Finally back from nationals. I unhooked the fuel line to the rail and I had a really good flow. Didn't test pressure, but everything looked OK there.
I tested both coils by grounding the plug to the manifold, and I have no spark.
What do I check next? Cam position sensor?
9/15/23 5:10 p.m.
I should’ve started with codes. I have three of them. One single flash, then a three flash, and an eight flash. The last one is for the airflow meter.
 Going to grab one and hang my head in shame.
9/21/23 1:47 p.m.
New AFM is in and still not starting.
Prior, the diagnostic codes were 1, 3, and a 8.  I've cleared them, and now I only have a diagnostic code 1.
Next step is to pull the coils and clean the connections (once I get the damn coils out).
Anything else I should be checking?
9/26/23 8:56 p.m.
For anyone following along, coil did the trick.
dr_strangeland
dr_strangeland Reader
9/27/23 11:18 a.m.
Ancient electrical component, sudden failure, sounds about right.
Jerry From LA
Jerry From LA SuperDork
9/27/23 11:32 a.m.
There's an old adage that 90 percent of fuel issues are spark.
7jvF6Dcu05ueieCQKKAO3On4QCFco6veXFqh9d0mDI5RbXyJCrB4RSpJO45dgM8E
