IndyJoe
IndyJoe New Reader
12/14/15 12:56 p.m.
Are the T-5 manual transmissions the same for the 3800 V6 as they are for the V8? (are they interchangeable)? Specifically will a 1995 T-5 out of a V6 car work for the V8?
Thanks in advance.
Ranger50
Ranger50 PowerDork
12/14/15 1:02 p.m.
Yes. Direct bolt in for the years listed, 1995. But if you want to backdate into a fox, a different input shaft and bearing retainer are needed.
Knurled
Knurled MegaDork
12/14/15 1:32 p.m.
Caveat: Watch input lengths. Something in my memory says the SN95 (maybe just New Edge?) had a slightly longer input shaft so you need to also use the V6 bellhousing.
IndyJoe
IndyJoe New Reader
12/14/15 1:37 p.m.
Ranger50 wrote: Yes. Direct bolt in for the years listed, 1995. But if you want to backdate into a fox, a different input shaft and bearing retainer are needed.
Thanks !
Robbie
Robbie SuperDork
12/14/15 2:42 p.m.
T5 had lots of changes over time. Looks like your question has been answered, but here is a link to the history of the t5:
http://www.moderndriveline.com/Technical_Bits/t5_history.htm
Dbussey1
Dbussey1 New Reader
12/14/15 3:38 p.m.
Correct. The Sn95 chassis cars have a longer input shaft than the earlier Fox body versions (93 and earlier).
I believe the difference is 5/8"
chiodos
chiodos HalfDork
12/14/15 4:40 p.m.
Different gears too. I only know this cause in the rwd Volvo world, ford t5 is the trans to have but only the v8 have the proper gears to match the redblock motors. Ymmv and it may not matter for you but something to look into
Js9tvm13SKM2KbI7U0Jga3e6cvFO4VJcjjY4KcVHV2WcLYfjX8mVQyJxY4nQATcV
