malibuguy
malibuguy New Reader
10/20/17 8:38 p.m.
Whipped this up the other night for my tercel.
1/8" plate and 12g 1" square tubing.  The center has a reinforcement plate inside the cowl to hopefully add strength.
Car feels amazing.  Almost disturbing how much this changed the feel of my car.  Damn near telepathic steering input.
Next I want to make an underbrace as the UR one doesnt fit with an automatic and I think I can make a better one.  Also I want to make fender braces.
Nick (Bo) Comstock
Nick (Bo) Comstock MegaDork
10/20/17 9:32 p.m.
Looks good!
Chadeux
Chadeux Dork
10/20/17 9:36 p.m.
I was once told a strut bar needed to be the closest thing to a straight bar that you can get. Looks like you nailed it.
LopRacer
LopRacer Dork
10/20/17 10:12 p.m.
Looks better than store bought and it's CUSTOM..... oooooo.....ahhhhhh.  I like it.
Floating Doc
Floating Doc Reader
10/20/17 10:20 p.m.
Nice work!
Ransom
Ransom PowerDork
10/21/17 12:36 a.m.
Very nice!
D2W
D2W HalfDork
10/21/17 10:26 a.m.
Very nice work
malibuguy
10/22/17 12:47 p.m.
Thank you guys.  Im pretty proud of it.
Ill get started on the underbrace next week
Toyman01
Toyman01 MegaDork
10/22/17 12:50 p.m.
That's a nice looking piece.
fasted58
fasted58 MegaDork
10/22/17 2:06 p.m.
That looks stout.
Nice work.
echoechoecho
echoechoecho Reader
10/22/17 3:53 p.m.
YES!!! more tercels on GRM! awesome job, how heavy is it?
Dusterbd13
Dusterbd13 UltimaDork
10/22/17 3:59 p.m.
I need to try this.
Can you explain the reinforcement plate more?
Fr3AkAzOiD
Fr3AkAzOiD Reader
10/22/17 9:25 p.m.
Looks good!
Strut bar helped a lot on my '05 Malibu that I take to HPDEs as well.
malibuguy
10/24/17 7:06 a.m.
In reply to echoechoecho :
The bar is about 2wice the weight of a factory starlet bar.  Which is surprising since the starlet bar feels like its made nearly out of tin
malibuguy
10/24/17 7:07 a.m.
In reply to Dusterbd13 :
The cowl is pretty thin sheetmetal so I made a plate for the backside (that the bolts are welded to as well) to help distribute the stress loads.
MadScientistMatt
MadScientistMatt PowerDork
10/24/17 7:22 a.m.
Very professional looking.
malibuguy
10/26/17 6:31 a.m.
made a lower bar yesterday.  Ill make it a 4point when I get more material.  It will go towards the back and pick up on the rear control arm mounts.
The plan is to build a splitter eventually and ill have tabs on this to mount it
Robbie
Robbie PowerDork
10/26/17 9:05 a.m.
excellent work. I need to do that lower bar on the saab.
Nick (Bo) Comstock
10/26/17 9:13 a.m.
I have plans to do this to the Civic as well. Taking notes.
echoechoecho
echoechoecho Reader
10/26/17 10:49 a.m.
I see you have those anti-lift plates, those things dont work. I did some testing on my tercel and all they do is bind up the suspension. Also get some OEM lower paseo braces, they will help stiffen the lower bar by triangulating it.
10/26/17 10:56 a.m.
I have a UR 4pt lower brace on my car, and I can tell you that you'll treasure any bit of ground clearance you can keep below the firewall area. Also it seems that the bar tying the forward mounting points of the front LCAs together makes more difference than the rear bar, from the accounts of people who put the JIC 2pt brace on the same model.
Recon1342
Recon1342 Reader
10/26/17 11:12 a.m.
This is why I love being a good welder.
Anything out out there will become whatever the berkeley I want it to be.
need a tool? Build it. Custom parts to help your car handle better? Build em. Bumpers? Easy. Roll cage? No problem...
malibuguy
10/27/17 8:03 p.m.
I took the braces off.  They come on these cars as well.  One of my bolts actually had chewed the threads up.  Went to chase em and snapped the chase.
I'll be pretty much rendering them useless once this becomes a 4pt.
I do not seem to get any bind.  My control arms moves very freely.
malibuguy
10/27/17 8:06 p.m.
In reply to GameboyRMH :
I still have my UR 4pt from my old car.  It hung low too.  I cannot use it on this current car because the auto does not clear it well.
malibuguy
10/27/17 8:16 p.m.
heres a much better shot of the UR brace on my old car
ZTGu846RjE5aRVwuHzguMq96DNUZIaYNQpWYfP3c1EGnX2rDrsV83f8VA3WB1MLl
