mrhappy
mrhappy HalfDork
10/28/12 5:09 p.m.
I have a 95 golf check engine light came on a while ago and I've been unable to get the car to flash the code.
This is what I'm doing. Koeo jump the 2 pins with a wire count to 3 and pull it out. The light stays on when the pins are jumped but when I pull the wire it goes out and doesn't flash.
What am I doing wrong?
jungle
jungle New Reader
10/29/12 12:07 p.m.
Often under the back seat base is a goofy plastic piece that is shaped like the odb port that has jumpers to trigger the flash codes.
I'd find somebody in the area w/ a VAGcom; there is a website database where ppl list who has them where. The VAGcom goes above & beyond the normal p-codes.
Paul_VR6
Paul_VR6 HalfDork
10/29/12 1:36 p.m.
There is no other connector on a 95, and I have never been able to jumper blink mine. Vag-com was the only thing that worked.
xflowgolf
xflowgolf Reader
10/29/12 1:48 p.m.
vagcom. yup.
mrhappy
mrhappy HalfDork
10/29/12 2:51 p.m.
Thanks for the help guys.
docwyte
docwyte HalfDork
10/29/12 3:24 p.m.
Make sure they have the OBD1 pig tail cord for the VAG.COM, most people don't at this point unless they're a professional mechanic.
jungle
jungle New Reader
10/29/12 3:40 p.m.
http://i662.photobucket.com/albums/uu343/alittlekuntry21/2012-08-07_19-36-38_789.jpg
16vCorey
16vCorey PowerDork
10/29/12 4:44 p.m.
I've got VAG-Com and the appropriate connector if you find yourself in Evansville, Indiana.
Paul_VR6
Paul_VR6 HalfDork
10/29/12 5:44 p.m.
95 uses the obd2 style connector and any version vagcom should work fine.
docwyte
docwyte HalfDork
10/30/12 9:23 a.m.
1995 is still OBD1, VW didn't go OBD2 until 1996.
Paul_VR6
Paul_VR6 HalfDork
11/1/12 9:36 p.m.
That is true but 95 uses the obd2 style plug not the 2x2/"ugly" connector like Corrados had. No adapter needed.
1JBkJCXiGSDrXJwa7srBk4aQQrrW5OCVqbBxPqZVmdtvGjvhmeFmAF8jZHdybKDx
