EvanB
EvanB MegaDork
6/5/18 2:09 p.m.
My challenge project involves putting a BMW K100 motorcycle engine in a car (HERE). Mounting the engine at a slight angle with the head higher would possibly solve some fitment issues. Are there any ways to make this work without killing the engine? Revised oil pickup? Baffled pan? Run oil slightly overfilled?
This is the engine for reference.
From looking at the last picture it appears that the oil pickup would be in the lowest part of the pan.
Professor_Brap
Professor_Brap Reader
6/5/18 2:27 p.m.
Id say send it, slap a oil pressure gauge in and if you start having issues overfill.
oldopelguy
oldopelguy UberDork
6/5/18 2:43 p.m.
It probably would be fine, but if you are really worried there's one more option.
EvanB
EvanB MegaDork
6/5/18 2:46 p.m.
I shouldn't have to get that drastic. I think I can get it to fit flat but a slight angle might make things easier. 5-10° maybe which shouldn't be an issue.
Tomorrow I am stripping the engine down and dropping it in to see how it looks.
BoxheadTim
BoxheadTim MegaDork
6/5/18 2:47 p.m.
How much is a "slight" angle? After all, a motorcycle engine doesn't tend to be perfectly horizontal all the time.
Edit: Looks like our posts crossed. I wouldn't worry too much about 5 degrees lean.
EvanB
EvanB MegaDork
6/5/18 2:52 p.m.
In reply to BoxheadTim :
Shouldn't have to do more than 10°, probably less. I figured it would be fine just running like that since motorcycles will be leaned over while running but didn't know about that in combination with the side loads from the car cornering.
Tyler H
Tyler H UltraDork
6/5/18 2:59 p.m.
Agreed.  These things already run at a 90' angle, so technically you would be running it at less of an angle.  :)
Engine looks clean!
EvanB
EvanB MegaDork
6/5/18 3:00 p.m.
In reply to Tyler H :
That isn't my actual engine, just a picture I found online. Mine still needs some cleanup.
Cactus
Cactus Reader
6/5/18 10:19 p.m.
I wouldn't even worry about a 10° lean on a bike engine.
Matthew Kennedy
Matthew Kennedy Reader
6/5/18 11:02 p.m.
If note is that while it looks like bike engines can run when tipped over pretty far, the acceleration vector is always very nearly straight towards the contact patch.  Otherwise the bike/rider would fall over! So bikes never really see much side loading, save for when transitioning, and even then it isn't anywhere close to the lateral loads experienced by a car.
markwemple
markwemple UberDork
6/6/18 10:54 a.m.
Maybe a sump baffle? Or a deeper sump? Or a dry sump?
Gaunt596
Gaunt596 Reader
6/6/18 10:59 a.m.
Where is the oil drain for the head? That needs to go on the low side. Other than that, send it.
APEowner
APEowner HalfDork
6/6/18 12:13 p.m.
This is an important consideration.  The cornering load vectors in a car are very different than in a bike and it's not uncommon to have oiling issues when bike engines are used in cars.  The best solution is to convert to a dry sump.  If that's not practical then the baffling may need to be reworked significantly.
edizzle89
edizzle89 Dork
6/6/18 1:23 p.m.
being a flat engine i'd think that even at a pretty steep angle the oil drain in the head would still be in a decent location
Trent
Trent UltimaDork
3/29/25 11:39 a.m.
So Evan, did your experiments with this ever come to anything?
kevlarcorolla
kevlarcorolla SuperDork
3/29/25 3:55 p.m.
I wouldn't worry too much,you can wheelie a bike a LONG ways without worry.
3/29/25 4:11 p.m.
In reply to kevlarcorolla :
Not Ducatis at least, from a 25 year old memory of a service manager who kept eating engines on a regular basis.
EvanB
EvanB MegaDork
3/29/25 5:11 p.m.
Nope, the engine is still sitting under my work bench waiting for something.
Trent
Trent UltimaDork
3/29/25 5:47 p.m.
I was just staring at the one under my workbench wondering if the pick up could be relocated and it tipped up. Quick google brought me here of course
3/29/25 5:52 p.m.
In reply to Trent :
Suprtfastmatt made a dry sump with parts he had made from sendcutsend.
kevlarcorolla
3/29/25 5:53 p.m.
In reply to Pete. (l33t FS) :
Haha,oppsie was his response? :)
3/29/25 7:41 p.m.
Two top end rebuilds, one bottom end rebuild, and a clutch in the first 3000mi.  And the fork seals blew out with regularity from landing.
This on a bike that was $25k in the mid 90s that he was making payments on.  It spent more time at the dealer than in his garage.
Sounded amazing, and might have been reliable if he wasn't a 20something with a sportbike.
3/30/25 8:19 a.m.
Never buy a bike from a squid.  Doing a wheelie for 1/2 mile or so oil starves the top end.  I'm guessing the BMW Engineers designed it to strict parameters, I wouldn't mess with it for fear of having all your work be for naught.   Is there room behind the driver's seat to put it?  Or, put the driver in the back seat and the engine aft of the firewall?
Driven5
Driven5 PowerDork
3/31/25 3:30 a.m.
This is what the critical oil lines look like during high lateral G loading. As long as there is enough oil to stay above the line, running it somewhat head up would look to be an overall improvement
CHioJuZ2Ty5Ot5LENWmfUp6VdwG9bb2rY98a7pUvFWPf3RWdusQ3crl5oz9LD21m
