evildky
evildky Dork
11/8/11 11:50 a.m.
I was thinking about the challenge results the other day and it occoured to me that the top 3 cars all were powerd by small block chevy's
gen 3 sbc powered BMW
gen 1 sbc powered VW
gen 2 powered F body
which is especially suprising since this was autocross and concourse only!
I guess I need a small block in my MR2
hrdlydangerous
hrdlydangerous Reader
11/8/11 12:52 p.m.
It's funny you should mention that, Dave. Paul Costas and I were laughing about that at the banquet. It's a big happy family of V8 goodness.
spin_out
spin_out Reader
11/8/11 1:05 p.m.
Of course, you point this out on the very day we decide to go from a V-8 car ('61 Buick motor) to a 4 cylinder turbo.
hrdlydangerous
11/8/11 1:22 p.m.
According to Wiki:
In 1961, Buick unveiled an entirely new small V8 engine with aluminum cylinder heads and cylinder block. Lightweight and powerful, the aluminum V8 also spawned a turbocharged version, (only in the 1962-63 Oldsmobile Cutlass version), the first ever offered in a passenger car.
I think this is the same engine you're running. Maybe you should keep the V8 and just add turbonium.
Toyman01
Toyman01 SuperDork
11/8/11 1:41 p.m.
There is no cheaper horspower than a SBC. It might not be elegant, but it works for not much money. That and they will run on the verge of exploding longer than a lot of engines will run.
Conquest351
Conquest351 HalfDork
11/8/11 1:51 p.m.
Toyman01 wrote: There is no cheaper horspower than a SBC. It might not be elegant, but it works for not much money. That and they will run on the verge of exploding longer than a lot of engines will run.
As a Ford guy, I unfortunately have to agree with the above statement.
Conquest351
11/8/11 1:52 p.m.
evildky wrote: I was thinking about the challenge results the other day and it occoured to me that the top 3 cars all were powerd by small block chevy's gen 3 sbc powered BMW gen 1 sbc powered VW gen 2 powered F body which is especially suprising since this was autocross and concourse only! I guess I need a small block in my MR2
The LS family will bolt to the Chevy F40 6-speed transaxle found in the Cobalt SS.
Just so ya know....
evildky
evildky Dork
11/8/11 2:00 p.m.
...and 2 of the 3 were automatic's!
I found it interesting that all 3 were different generations of sbc
RossD
RossD SuperDork
11/8/11 2:34 p.m.
The one thing the SBF has going for it, compared to the SBC, is it's slightly smaller size.
pinchvalve
pinchvalve SuperDork
11/8/11 2:41 p.m.
Why is there no medium block?
a401cj
a401cj Reader
11/8/11 4:44 p.m.
pinchvalve wrote: Why is there no medium block?
I think the 350-455 Buicks could be considered "medium" blocks. They are way lighter than a big block Chevy, Ford, or Mopar. Not even very much heavier than a small block Chevy
Gearheadotaku
Gearheadotaku Dork
11/8/11 7:30 p.m.
Because all is right in the world when at the throttle of a V8 Chevy
RossD
RossD SuperDork
11/8/11 7:48 p.m.
Gearheadotaku wrote: Because all is right in the world when at the throttle of a V8 Chevy
I heard that the Chinese have a single character for that sentence.
Taiden
Taiden Dork
11/8/11 7:53 p.m.
I'm still waiting to run across info on a cheap 5 speed that holds up to gen3 or gen4 power levels that bolts up
Taiden
Taiden Dork
11/8/11 7:55 p.m.
Also who ran the BMW and what was it exactly?
hrdlydangerous
11/8/11 8:03 p.m.
In reply to Taiden:
It was the Vorshlag team. The car was in the mag a few months back but they brought it back with a really cool BMW art car paint job. It has a 5.3 LS truck block and lots of fab work using E36 suspension bits. Unfortunately the only trans they can budget for is a V-6 Camaro 5 speed. I think this year's drag run claimed trans #3.
evildky
evildky Dork
11/8/11 10:54 p.m.
Why are there so few manual trans V8 F bodies? Or is it just that there are so few V8 F bodies?
Isn't the ford WC T5 stronger than the GM T5? The fords seem more common (in my area at least). Should still bolt to their aftermarket scattershield right?
Will
Will Dork
11/9/11 6:01 a.m.
RossD wrote: The one thing the SBF has going for it, compared to the SBC, is it's slightly smaller size.
In general you're right, though the front-mounted distributor on the SBF comes in handy when trying to fit the engine in some applications. But SBF stuff tends to be a lot more expensive.
tuna55
tuna55 SuperDork
11/9/11 7:26 a.m.
The LS family will bolt to the Chevy F40 6-speed transaxle found in the Cobalt SS. Just so ya know....
Tell me more about this.
Gearheadotaku
Gearheadotaku Dork
11/9/11 7:46 a.m.
Taiden wrote: I'm still waiting to run across info on a cheap 5 speed that holds up to gen3 or gen4 power levels that bolts up
The NV3500 from the 99-04 1/2 ton Chevy pickup works, but the gearing is all wrong for sports car use. A tremec T5 works too, but is not cheap. Thats seems to be the limiting (sort of) factor with LS engines. If you want a manual it's either an old muncie 4-speed (goodbye overdrive if you need it) or a big bucks late model 6 speed.
81cpcamaro
81cpcamaro Reader
11/9/11 8:03 a.m.
Unfortunately GM skipped over a good 5-speed to go directly to the T56 when the Camaro/Firebirds started making good power (LT1 & LS1 models). The NV3500 from a S10 has a little better gearing than the full-size trucks, but still not ideal for sports cars. Shifter location for the NV3500 is a bit too far forward for car use as well. Good thing is the 6-speed prices seem to be coming down some, while the older 4-speeds are going up. If you have taller rear gears, there are some good deals on the Richmond 5-speeds out there (no overdrive with Richmond, 5th is 1:1).
evildky
evildky Dork
11/9/11 11:53 a.m.
I think thats why I tend to gravitate to the imports, automatic's in the japanese entheusiast cars are kinda rare, while domestic tend to make a lot more automatic entheusiast cars, and I like banging gears
Taiden
Taiden Dork
11/9/11 11:59 a.m.
81cpcamaro wrote: Unfortunately GM skipped over a good 5-speed to go directly to the T56 when the Camaro/Firebirds started making good power (LT1 & LS1 models). The NV3500 from a S10 has a little better gearing than the full-size trucks, but still not ideal for sports cars. Shifter location for the NV3500 is a bit too far forward for car use as well. Good thing is the 6-speed prices seem to be coming down some, while the older 4-speeds are going up. If you have taller rear gears, there are some good deals on the Richmond 5-speeds out there (no overdrive with Richmond, 5th is 1:1).
One can easily go down to a 2.79 or 2.93 rear diff in the e30. Is this low enough dya think?
Gearheadotaku
Gearheadotaku Dork
11/9/11 3:07 p.m.
Well, check the ratio's in the trans you are looking at along with your tire size and desired speed in each gear.
Taiden
Taiden Dork
11/9/11 4:06 p.m.
Gearheadotaku wrote: Well, check the ratio's in the trans you are looking at along with your tire size and desired speed in each gear.
Yeah. I admit laziness on my part. I'll do that.
bVATsBKH8LII09aR5lhH430PlIDIDtTOromxiR6kaHqa4AgzO0honKklNNjUAMYq
