ronholm
ronholm Reader
11/27/12 12:16 p.m.
Oh no. All I have to do is pick it up.
Just what I needed.
Rusted_Busted_Spit
Rusted_Busted_Spit UltraDork
11/27/12 12:24 p.m.
Keep us posted.
Cone_Junky
Cone_Junky Dork
11/27/12 12:34 p.m.
oldtin wrote: Electrics - redundant/duplicate systems 2- ECUs for example, I see quite a few runners with around 750-1500. Typical bmw stuff like plastic cooling parts. Running/working maybe 2000. Little value, can be expensive to fix. Personally consider it about the least desirable bmw.
My thoughts exactly. My shop, a BMW specialist, won't touch them. Hardware replacement and maintenance maybe, but only if the car looks to be well kept. But most are rodents because nobody can afford to fix them or find somebody willing to work on them.
Strike_Zero
Strike_Zero Dork
11/27/12 12:44 p.m.
Build thread!!
m4ff3w
m4ff3w UltraDork
11/27/12 12:50 p.m.
I want a M70+manual trans in a e28 or even e34.
m4ff3w
m4ff3w UltraDork
11/27/12 12:51 p.m.
If you pass on it, can I call dibs? I'm in San Antonio, but could make the drive.
slefain
slefain SuperDork
11/27/12 12:51 p.m.
LSX and a T-56?
wspohn
wspohn Reader
11/27/12 1:28 p.m.
This reminds me of dead Jag XJ12 stories.
Wise men drive them until something (even something that can look fairly trivial) fails and then abandons them at the road side.
Fools decide to fix them and wind up with 3 -4 times as much into an engine rebuild as they could turn around and sell the whole car with rebuilt engine for.
Only the Bimmer is even worse, mostly due to parts cost and potential for complex electrical issues.
nocones
nocones Dork
11/27/12 1:37 p.m.
Swap in Jag V12? Through GRM I've learned Best motor all time.
93EXCivic
93EXCivic MegaDork
11/27/12 1:43 p.m.
mad_machine wrote: I remember reading an article on a hotrod that used the BMW V12.. it worked VERY well and was very unique. They too mentioned that getting rid of the stock ECUs and injection made working on the engine MUCH easier
There was an Ultima GTR at the SSC USCC one year that had a BMW V12 with two SDS engime management systems on it.
dculberson
dculberson SuperDork
11/27/12 2:00 p.m.
There is a BMW L7 in the local Pick-N-Pull, and I spent some time poring over it. The stitched leather dash was really impressive. The general finish level inside was really nice. I don't think the 750il is quite as nice inside, but dang was it neat/sad to see in the junkyard.
belteshazzar
belteshazzar UberDork
11/27/12 2:34 p.m.
for all the same reason's that i have no interest in audi's or jags, I SHOULDn't want one of these....
but i still do.
m4ff3w
m4ff3w UltraDork
11/27/12 2:42 p.m.
Basically a McLaren F1 mule.
dean1484
dean1484 UltraDork
11/27/12 2:54 p.m.
I see these cars quite often in CL. They are basicly selling for scrap value (even when running). If you got that car cheep enough I would do the minumum to get it running and flip it. Then take $$$$ and go get a 540I Sport
RossD
RossD UberDork
11/27/12 4:30 p.m.
  1. Get car home.
  2. Remove engine, transmission, and all electrical luxury items
  3. Install Favorite 'murican V8, manual transmission, and 4 race or almost race seats
  4. Hoon.
  5. Receive internet high fives.
singleslammer
singleslammer HalfDork
11/27/12 4:33 p.m.
Why not just strip the big 12 of all the electronic crap on it, squirt it, and adapt a transmission of your choice as described above. The adapter plate between the bell housing and the manual trans shouldn't cost too much to have made up.
m4ff3w
m4ff3w UltraDork
11/27/12 4:51 p.m.
singleslammer wrote: Why not just strip the big 12 of all the electronic crap on it, squirt it, install a pair of turbos and adapt a transmission of your choice as described above. The adapter plate between the bell housing and the manual trans shouldn't cost too much to have made up.
FTFY.
jakeb
jakeb Reader
11/27/12 7:42 p.m.
singleslammer wrote: Why not just strip the big 12 of all the electronic crap on it, squirt it, and adapt a transmission of your choice as described above. The adapter plate between the bell housing and the manual trans shouldn't cost too much to have made up.
This sounds like the best idea...oh and turbos
singleslammer
11/27/12 8:04 p.m.
Agreed
Mitchell
Mitchell SuperDork
11/27/12 8:59 p.m.
Equip your garage with new BMW leather seating?
sethmeister4
sethmeister4 Reader
11/27/12 9:11 p.m.
My gut tells me you should probably run...I watched my buddy do a starter on his 92 325i the other day. What a nightmare! What were the Germans thinking?! A V12 is going to be SO much worse than a 3 series, I'm sure. On the other hand, I'd love to see this thing all hot-rodded up! Hope you can get it for $500 or less!
chaparral
chaparral HalfDork
11/27/12 9:13 p.m.
Yank the twelve-banger.
Build two exhaust manifolds, complete with GT2259s.
Set up an aftermarket injection system
Install it in a 94-99 Mustang.
curtis73
curtis73 SuperDork
11/27/12 9:44 p.m.
If you pay anything close to its actual value, you are paying 10 times too much IMO.
If you have emissions in your area, be prepared to replace cats every 60k or so... to the tune of $1400 each. Radiators pretty consistently leak at the tank seal, and there are no real aftermarket options that don't suck. Plan on dropping $400 for a new one from 1-800 Radiator.
Parts are made from unobtanium, so if you have a valve cover leak, an oil pan leak, a water pump go, or need an injector or something, plan on opening the really big wallet. Scratch that... the JUMBO wallet.
The other possibility is to just drive it until you have one of those problems and then just drop in a Viper V10.
m4ff3w
m4ff3w UltraDork
11/27/12 9:47 p.m.
curtis73 wrote: If you pay anything close to its actual value, you are paying 10 times too much IMO. If you have emissions in your area, be prepared to replace cats every 60k or so... to the tune of $1400 each. Radiators pretty consistently leak at the tank seal, and there are no real aftermarket options that don't suck. Plan on dropping $400 for a new one from 1-800 Radiator. Parts are made from unobtanium, so if you have a valve cover leak, an oil pan leak, a water pump go, or need an injector or something, plan on opening the really big wallet. Scratch that... the *JUMBO* wallet. The other possibility is to just drive it until you have one of those problems and then just drop in a Viper V10.
Why does this make me want one more?
ronholm
ronholm Reader
11/27/12 11:45 p.m.
Surfing parts online doesn't seem to be that scary. And lots of cheap parts cars around.
And yeah. The price was right. I'll just leave it at that.
cwEUGklX2qsVsa2WtrmEPPKcntX4p8Krbn9Y2oyzpPoA1kp49mC0rF6iAWJWI3ZH
