Foxworx
Foxworx Reader
9/17/19 2:11 p.m.
Hey All,
I have a 01 Miata that has been sitting outside (both under roof and 2 car-covers) for a few years. I'd been in the midst of a full rebuild/reassembly after painting and installing Tubular suspension etc.... when we bought a house.
Question is. The tires (Toyo R1R) are (were) brand new (driven 2 miles?). Do we think they've lost a lot of their 'quality' (for lack of a better word) sitting for a while.
Under the covers they don't get UV and look as new.
Experiences?
Cheers,
Fox
9/17/19 2:14 p.m.
They might have become a bit crusty and lost some grip over the years, but if they're under 5 years old and have no visible signs of degradation I wouldn't think twice about running them.
Fueled by Caffeine
Fueled by Caffeine MegaDork
9/17/19 2:19 p.m.
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=138
If they weren't cracked.. Id run them..  Won't be as sticky as new, but they'll be fine.
bobzilla
bobzilla MegaDork
9/17/19 2:20 p.m.
Agreed... they'll be slick but they should be integrally fine. Once those tires get below about 40*F they start to harden. The more times they go up and down, along with the UV the worse they deteriortate.
z31maniac
z31maniac MegaDork
9/17/19 2:59 p.m.
Step 1: Lick the stamp.
Step 2: Send it!
dclafleur
dclafleur Reader
9/17/19 3:10 p.m.
If they haven't cracked I'd say you're good, biggest issue I've had with tires that sat was flat spotting.
Driven5
Driven5 UltraDork
9/17/19 4:21 p.m.
Even if covered, mounted and sitting outside is still going to age them.  I'd consider running them up to 5, maybe 6, years old.  Much beyond that and looks can be deceiving. No cracking on old tires does not mean no problem...Just ask Paul Walker and Roger Rodas' families.
Tom1200
Tom1200 Dork
9/17/19 8:52 p.m.
I'd be ok with them for initial testing / sorting of the car but I wouldn't use them for sustained high speed running nor track work.
They'll be well down on grip so you won't get any sort of valid set up done with them. If it's just to make sure everything is operable (read drive it around the block to see if anything leaks) that's fine.
You can't do a real suspension set up done on old hard tires. Structurally they likely fine but don't waste your time.
zSntBIms52kxlnev92pmvkpgd0NJaLSNEHt7Lp4Rpx0N4oFvPTxwRpZg3Gwu4Lsi
