Now that I got the 15 x 7s for the Soccer Mom Challenge Safari I need to get tires. Need them to help lower the van so 50 series or less I suppose. Ideas? Don't think Tirerack's computer will help me out here.
SM7s were my first thought because they are so easy to get used but not sure they'll be wide enough for you.
¯\_(ツ)_/¯ wrote: Lots of nice sticky stuff in 225/45r15 (about 23" tall)
That was my thought. A slight squeeze, but surely it puts a little more rubber on the ground, and the load rating will be more in line with the van's weight.
WildScotsRacing wrote:¯\_(ツ)_/¯ wrote: Lots of nice sticky stuff in 225/45r15 (about 23" tall)That was my thought. A slight squeeze, but surely it puts a little more rubber on the ground, and the load rating will be more in line with the van's weight.
That's A LOT of squeeze. I'd recommend 195/50/15s on a 15x7. That's the same setup I have on the Corolla.
Stampie wrote: SM7s were my first thought because they are so easy to get used but not sure they'll be wide enough for you.
Second this. It's a 205/50 15 so should fit better than the 225 on a 7" rim. A full set of take-offs are available from various sources for about $250 shipped.
Stampie wrote: Those look to be in decent shape and good price.
Why do they look like they've been cooked into hockey pucks?
In reply to WildScotsRacing:
I was looking at the tread. Being in Florida I wouldn't know what a hockey puck looks like but I understand baked for sure. Can you educate me?
The "booger" on this looks suspect
And at second glance this one looks weird on the right side.
I don't know ... was I expecting to much for a set of $75 Challenge tires?
The "booger" as you put it is OPR (other people's rubber). Common to pick up with hot tires when racing. It looks like those have a build date of 11-15 so not too old. I'd ask about heat cycles but for a minivan they probably have more grip than you'll be able to use.
Google John Burget Tires and give him a call. He may have something that would work.
In reply to KyAllroad:
Yes, either heat cycled or over-heated/over-driven into hockey pucks, as in as-hard-as-a-hockey puck; = hardened to the point of low grip.
