ReverendDexter
ReverendDexter Dork
5/27/10 7:16 p.m.
As the title says, why don't I want an '84 318i?
Cheap one on CL, and I need a better commuter than my '96 5.0 Bronco and my Foxbody 'vert, both of which are automatics, get about 12mpg, and the Mustang is missing it's rear window panel, making it a no-go when it's wet out.
Seems like the Bimmer'd be a fun little car assuming it's a stick (I won't buy another auto); I see that year was offered with both 4 and 5 speeds and 3 different gear ratios in the diff, is there any correlation between tranny and what it's geared?
Is there a good reason to hold out for a 325i instead? I'm not looking for power, I'm looking for something I can have fun with on my drive to work and not garner too much attention from Johnny Law. Spec-wise it seems pretty close to an AE86 (my favorite of all my past cars), just a little heavier, but with more torque and IRS.
Does suspension interchange with other E30s? Is there any chance it's manual steering (please say yes)? I don't want to get a car I can't mod due to being eclipsed by the more popular I6 cars.
Thanks everybody
carzan
carzan Reader
5/27/10 7:30 p.m.
I had an '85. Mine had drum brakes in the rear. I loved it anyway.
I have a turbo manifold for it. If it was in my price-range and in decent shape (as well as in my traveling range), you'd be outta luck. I would've bought it already.
fastbmw
fastbmw New Reader
5/27/10 7:37 p.m.
The 84 318i is a fine little car, just about every suspension bit will swap over from any other e30 (minus the ix). The 318i has power steering but if you really want, you can just cut the PS belt.....haha
Don't bother with modding the engine, if you are inclinded to, just buy a 325i or even a 325e.
Good luck!
belteshazzar
belteshazzar SuperDork
5/27/10 8:22 p.m.
I had an 85 318i for a dd. It was awesome & perfect. I'm a fool for selling it.
ReverendDexter
ReverendDexter Dork
5/27/10 8:40 p.m.
Am I deluding myself to think the 318i would feel at all like my AE86 SR5?
njansenv
njansenv Reader
5/27/10 8:50 p.m.
I'm not sure, but it would be very tossable. Those motors are pretty stout, should you decide to boost it down the road. I've heard of folks running 350whp on the stock motors. I love E30's. I really do.
Nathan
m4ff3w
m4ff3w SuperDork
5/27/10 9:21 p.m.
Boost the E36 M3 out of it.
ReverendDexter
ReverendDexter Dork
5/27/10 11:32 p.m.
If I do pick it up, it'll have to stay sans boost due to Cali smog laws.
'side, if I want boost, I'd rather make turn the Bronco into a Lightning-killer (well killer might be optimistic, hahaha).
z31maniac
z31maniac Dork
5/28/10 7:18 a.m.
Smaller strut tubes (meaning a swap to later units if you want to upgrade the struts), drum rear brakes (just a rear trailing arm swap away), the M10 is gutless.
M030
M030 HalfDork
5/28/10 9:11 a.m.
I test drove one this past Wednesday in 100 degree heat. No A/C, black vinyl seats and the windows wouldn't roll down. Other than that it was a blast!
belteshazzar
5/28/10 9:15 a.m.
ReverendDexter wrote: Am I deluding myself to think the 318i would feel at all like my AE86 SR5?
I've had an M10 E30, and I've had a GT-S AE86.
The 4AGE is more, idunno, zingy? The toyota was a great car.
The M10 sounds a lot cooler in my opinion. I'd rather work on the bimmer, though I can't quantify that thought.
It's an interesting comparison. They each have a very different feel to them. But I'm not sure which is "better". Each handle great and are fun to drive at 10/10ths.
ditchdigger
ditchdigger Reader
5/28/10 10:56 a.m.
The entire time I had my 325is I never once thought that it could use less torque and HP.
carzan
carzan Reader
5/28/10 12:06 p.m.
ditchdigger wrote: The entire time I had my 325is I never once thought that it could use less torque and HP.
That's a pretty universal statement, isn't it?
"The entire time I had my insert make/model here I never once thought that it could use less torque and HP"
grimmelshanks
grimmelshanks Reader
5/28/10 12:28 p.m.
get the e30 and be happy. trust me, you will be happy
1988RedT2
1988RedT2 New Reader
5/28/10 12:34 p.m.
You want it.
Marjorie Suddard
5/28/10 1:05 p.m.
I loved mine. Still miss it. Margie
red5_02
red5_02 New Reader
5/28/10 1:16 p.m.
Buy it then pull the M10 and drop in an M20 six. The shorter gears in the rear end will make it pull HARD. Friend of mine did this on his 318. With a little port work, double valve springs and a mild cam that baby hauled!
Buzz Killington
Buzz Killington Reader
5/28/10 1:19 p.m.
I've had an M10 E30, and I've had a GT-S AE86. The 4AGE is more, idunno, zingy? The toyota was a great car. The M10 sounds a lot cooler in my opinion. I'd rather work on the bimmer, though I can't quantify that thought. It's an interesting comparison. They each have a very different feel to them. But I'm not sure which is "better". Each handle great and are fun to drive at 10/10ths.
SR-5 = not 4A-GE.
z31maniac
z31maniac Dork
5/28/10 2:53 p.m.
red5_02 wrote: Buy it then pull the M10 and drop in an M20 six. The shorter gears in the rear end will make it pull HARD. Friend of mine did this on his 318. With a little port work, double valve springs and a mild cam that baby hauled!
Incorrect.
Buy it, pull M10, update suspension with later model pieces.
Then add S52B32.
John Brown
John Brown SuperDork
5/28/10 3:01 p.m.
Incorrect. Buy it, pull M10, update suspension with later model M3 pieces. Then add LS9
red5_02
red5_02 New Reader
5/28/10 6:54 p.m.
Don't forget the solid driveshafts lol
belteshazzar
5/28/10 9:24 p.m.
SR-5 = not 4A-GE.
well I DEFINITELY wouldn't pick the base model over a 318i.
2002maniac
2002maniac Reader
5/28/10 9:29 p.m.
Incorrect. Buy it, pull M10, update suspension with later model pieces. Then add S52B32.
Then part it out and get a 350z?
njansenv
njansenv Reader
5/28/10 10:35 p.m.
I'm pretty sure the transmission in that car bolts right to the M30 (3.5L) big six.
I'm just saying....
ReverendDexter
ReverendDexter Dork
5/29/10 10:11 a.m.
carzan wrote: That's a pretty universal statement, isn't it? "The entire time I had my *insert make/model here* I never once thought that it could use less torque and HP"
Honestly? Ever time I was driving my commute in the Cobra, I wished it had had less power. That way I could've driven it "harder" while still staying at sane speeds. Having to drive like a grandma sucks.
And for the SR5 vs GT-S debate, my SR5 surprised a lot of people. I had removed all the extraneous engine accessories, so the only things the motor was turning were the water pump and alternator. I freed up the intake and exhaust, and when all was said and done, it made more torque than a GT-S (though still a pretty significant hp and rpm deficit). Dyno proven 65hp to the wheels, yo!
q9NHEk2g09OQ98Kif5k7tZeJlRYtOJ5F8wFrCtOH7ljuR8HNk6hJeS2ibr9JfuoU
