1/16/14 7:18 a.m.
Common problem: Your tires are too hot because you got loose, or because your tires just aren't up to how long you've been out on track. So you have to take it easy for a couple of minutes to let the temperature decrease, and that sucks especially if you're actually in a race.
Apparently easy solution: Water spray nozzles pointed at the tires. Pressing a button to spray the tires will rapidly cool them and on a dry day they'll be dry again in seconds.
Could be especially convenient for the autocross crowd who likes to spray their tires with garden sprayers between runs. Could also be useful for extending tire life for the drift & burnout crowd (although it will reduce smoke...still, great for drift practice).
Why has nobody done this?
jstein77
jstein77 SuperDork
1/16/14 7:25 a.m.
Good idea, but tank size and weight could be an issue.
1/16/14 7:27 a.m.
The tank wouldn't need to be that big...depends on how much you want to carry. An average car washer tank carries plenty. I was thinking the wide-pattern spray nozzles on recent GM vehicles that make it impossible to see where you're going when you wet the windshield would be ideal.
tuna55
tuna55 PowerDork
1/16/14 7:32 a.m.
Folks have, but mostly for burnouts
http://www.twoguysgarage.com/forum/archive/index.php?t-2616.html
http://www.jalopyjournal.com/forum/archive/index.php/t-719103.html
MadScientistMatt
MadScientistMatt UltraDork
1/16/14 7:36 a.m.
I suspect the rulebook is the biggest reason this hasn't been tried - it is something that sounds like a tech inspector might think it's dangerous, or would violate rules against spilling anything on the track.
1/16/14 7:44 a.m.
I was thinking about the track spillage issue...many rule sets allow brake or IC / radiator water spray and this isn't any worse.
captdownshift
captdownshift Reader
1/16/14 8:00 a.m.
flashback to topgear driving up a volcano
codrus
codrus HalfDork
1/16/14 8:03 a.m.
For autocross it's probably not allowed in Stock/Street, SP, and ST classes because the rules are structured as "if it isn't explicitly permitted, then it's forbidden".
Dr. Hess
Dr. Hess MegaDork
1/16/14 8:11 a.m.
GRM did it to an AE86 for a do-rift-o event, but they wouldn't let them run it.
Gimp
Gimp SuperDork
1/16/14 8:12 a.m.
I can see getting a black flag for dumping fluids on the track.
1/16/14 8:20 a.m.
Maybe tire CO2 spray then?
81cpcamaro
81cpcamaro HalfDork
1/16/14 8:32 a.m.
GM offered a system like this back in the 60's, to help with traction in winter. It was the option V75 Traction Compound Dispenser. You can see more here: http://www.yenko.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=419018&page=all
I agree most tracks would frown upon this. It would probably take quite a bit of water to cool the tires down at speed, thus leaving water on the track.
iceracer
iceracer UberDork
1/16/14 9:14 a.m.
Nothing like getting your tires wet during a race.
Apexcarver
Apexcarver PowerDork
1/16/14 9:18 a.m.
You would never want it to accidentally deploy in the middle of a run, so having an on-board system isnt worth the risk. (it could cause an accident)
Honestly, I have thought on hot days having a water box to pull through post-run would be nice as opposed to garden sprayers.
Maybe get some big old towels, wet them and run them over. BAM tires cooled.
yamaha
yamaha PowerDork
1/16/14 9:53 a.m.
Yea, I don't think I want any of my tires getting wet in dry conditions when I'm autoxing.....then again, mine always seemed to stick even better as their temp went up.
DaveEstey
DaveEstey UltraDork
1/16/14 10:00 a.m.
spraying water only cools the surface, not the core, which remains hot.
jstein77
jstein77 SuperDork
1/16/14 10:51 a.m.
captdownshift wrote: flashback to topgear driving up a volcano
Didn't they spike theirs with Vodka?
Joe Gearin
1/16/14 10:59 a.m.
Dr. Hess wrote: GRM did it to an AE86 for a do-rift-o event, but they wouldn't let them run it.
Wow! Good memory Dr. Hess! That was at least 10 years ago now. The system we installed in the AE86 was a 5 gallon water tank anchored into the hatch, hooked up to a marine bilge pump-- activated by a switch on the dash. It worked well, but pumped a ton of water onto the tires. It probably would have been a better set-up with a finer spray nozzle at the end of those hoses. It would be a fun set-up for hooning around in an underpowered RWD car, (like the AE86) as oversteer was a switch-flick away!
Swank Force One
Swank Force One MegaDork
1/16/14 11:00 a.m.
Came in here to post this.
wbjones
wbjones PowerDork
1/16/14 12:17 p.m.
DaveEstey wrote: spraying water only cools the surface, not the core, which remains hot.
that's why you (at least I) start spraying after the first run … but then I'm running Toyo R1R's and you HAVE to spray
1/16/14 12:18 p.m.
Yep, to keep it from freezing.
oldeskewltoy
oldeskewltoy Dork
1/16/14 12:41 p.m.
Slightly off topic.... Ford used something like this on the brakes for the Group 2 Capri (early 70s)
codrus
codrus HalfDork
1/16/14 1:13 p.m.
Yes, if you wait until the tires get greasy it's too late. With my Hoosiers I'll usually let them sit after the first run and start spraying after run #2.
wearymicrobe
wearymicrobe Dork
1/16/14 1:51 p.m.
oldeskewltoy wrote: Slightly off topic.... Ford used something like this on the brakes for the Group 2 Capri (early 70s)
For brakes maybe. The GTR guys do this for brake cooling all the time at the track.
53erx8HnEXfHsjA3g8T2dAeeO7nYBiHhhHCiUVZHtM6MTJJ3a1wohQRW2AfEBlfZ
