Javelin
Javelin MegaDork
3/31/13 11:48 p.m.
The new carburetor solved all the problems, the 360 runs great again.
Guess what's wrong with the picture on my blog for an internet cookie. No winners yet!
ransom
ransom UltraDork
3/31/13 11:56 p.m.
No vacuum advance connected?
No battery hold-down?
Valve cover too shiny?
Travis_K
Travis_K UltraDork
4/1/13 12:05 a.m.
Missing fuel line clamps?
fasted58
fasted58 UberDork
4/1/13 12:31 a.m.
wrong vac port?
dizzy is now correct connected to ported vac
moparman76_69
moparman76_69 HalfDork
4/1/13 5:52 a.m.
It's hard to tell because of the glare, but the throttle and kickdown don't appear to be connected.
Ranger50
Ranger50 PowerDork
4/1/13 6:28 a.m.
It's an AMC????
HappyAndy
HappyAndy Dork
4/1/13 6:32 a.m.
No fuel line hose clamps?
moparman76_69
4/1/13 6:34 a.m.
I'm not sure it has a fuel line connected to the carb.
Edit: Nevermind it has a banjo bolt on the carb.
cutter67
cutter67 HalfDork
4/1/13 6:44 a.m.
you left the labels on the rad hoses.....really ugly
i would have routed the sparkplug wires under the hose instead of over the oil fill
JeffHarbert
JeffHarbert Reader
4/1/13 7:16 a.m.
The blinker fluid tank is empty.
bravenrace
bravenrace PowerDork
4/1/13 7:18 a.m.
Where to start...
NGTD
NGTD Dork
4/1/13 7:23 a.m.
Ranger50 wrote: It's an AMC????
+1
Javelin
Javelin MegaDork
4/1/13 8:29 a.m.
ransom wrote: No vacuum advance connected? No battery hold-down? Valve cover too shiny?
Vacuum advance is connected (vacuum hose on the passenger front of the carb).
Battery uses the stock hold down located at the base of the battery (see other pictures).
Valve cover is not too shiny!
Javelin
Javelin MegaDork
4/1/13 8:30 a.m.
moparman76_69 wrote: It's hard to tell because of the glare, but the throttle and kickdown don't appear to be connected.
Ding, ding, ding!
Javelin
Javelin MegaDork
4/1/13 8:32 a.m.
fasted58 wrote: wrong vac port? dizzy is now correct connected to ported vac
Hrm, you sir appear to be correct. Apparently the ports are different on the POS Motorcraft, I shall go change that.
Also, yes, it was missing one fuel hose clamp in the shot, which has since been reinstalled, and the plug wires normally go down behind the oil fill. I probably should take the stickers off the radiator hose though.
AngryCorvair
AngryCorvair PowerDork
4/1/13 9:33 a.m.
not enough titties?
fasted58
fasted58 UberDork
4/1/13 11:08 a.m.
In reply to Javelin:
Pic is right, passenger side port is ported vac
I was betting you might have used the manifold vac before
eastpark
eastpark Reader
4/1/13 3:50 p.m.
AC wins!
spitfirebill
spitfirebill UltraDork
4/1/13 4:00 p.m.
AngryCorvair wrote: not enough titties?
definitely
JludyNsUkP6tlv7w9dffB0o6d1YO5qksFRdAAMsJYNo2aLf8rAIWj4m1D4eKYQVT
