Ian F
UltimaDork
1/21/14 8:34 a.m.
...or Bugeyron?
http://www.carscoops.com/2013/02/the-bugatti-veyronbeetle-edition.html
I know it's just a computer rendering, but for some reason I like it better than either of the originals. I'd actually ponder building one if a kit became available.
The want is super strong with this one. It's one of my rotating wallpapers. I want to build one out of aluminum, but the powertrain has me perplexed. What period correct powertrain would you use in something like that?
Let's brainstorm shall we?
neat, but I don't get a race-car vibe from it. The Veyron is one part hyper car one part luxury car, and I'd think that a 50's version would be more like an early Lambo or Porsche.
Much better looking than the original. If you wanted a period correct powertrain, how about a small block Chevy, Ford 427 Side Oiler, or Chrysler Hemi with Weber IDAs or DCOEs and velocity stacks?
Whilst I agree a V8 would be awesome, the Veyron has a "weird" engine. W16 with 4 turbochargers. I was thinking some sort of aircraft engine? Merlin would be too large, but awesome. Any other ideas?
Powar
SuperDork
1/21/14 9:13 a.m.
That looks wonderful... especially when compared to the fugly Veyron.
Shouldn't be too hard to find a good cheap gently used mid 50's 251 engine should it?
In reply to bigdaddylee82:
I like your thought process. Something like that with a supercharger or turbo(s)? What other "period correct" engines are there? Something strange, but powerful. I'd think something in the 600-700hp range would be about right as the new Veyron is over 1,000hp. Napier Deltic engine? Were they made small enough?
while the flat Porsche 6 was not around in the 50s.. done up with velocity stacks, it would look at home in there.
I wish there was an available flat or V12 air cooled that would go back there. THAT would be ideal.
Aren't there numerous flat 6 aircraft engines that are air cooled? If you dig deep enough you may even find a flat 8. Lycoming and Continental come to mind.
I agree that a Porsche flat six, or Corvair, with stacks would have the right look.
And if that were a kit, I'd be putting a deposit on it now.
For "weirdness" level, I'd go with a 917 flat-12.
That's not being realistic, though...
Ian F
UltimaDork
1/21/14 10:47 a.m.
In budget-no-object build I'd 'want' a 914-6, air-cooled mid-engine set-up. If I were building one with my own money: WRX drivetrain a la FFR 919, with the side-scoops functional to feed air to twin side radiators.
I was thinking a 917 flat 12 would be ideal, but you're not going to find that. Maybe a Ryan Falconer V12 that's made from Chevy parts?
Some Tatra trucks have big air cooled 19.0 liter diesel V12s
Rufledt
SuperDork
1/21/14 3:24 p.m.
Agreed, lots of want.
I would the car to be as small as possible, but the engine to have as many cylinders as possible, because I like extremes. The ferrari 288 GTO had a longitudinal mounted 2855cc twin turbo V8, imagine this is a magical land where you can easily stick an extra 4 cylinders on it making a 4283cc twin turbo V12. Bingo.
Or for a more period correct option, use this engine from a miata:
recreate it all in aluminum (because I want it to weight less than the rest of the car) and add some turbos.
fanfoy
HalfDork
1/21/14 3:46 p.m.
V8? Check
Air-cooled? Check
Available in the 50's? check
In a rear-engined car? check
We have a winner!
Ian F
UltimaDork
1/21/14 3:47 p.m.
Umm... how about two Subie engines with a common crank?
It's a VW. Shouldn't that mean the right engine is merely a custom billet block, crank, and cam plus 12 ACVW pistons and 6 cylinder heads all fed through one 24" long Judson supercharger?
for that matter.. you could run SCAT individual cylinder heads and just weld the blocks together with a custom flat 12 crank
I'd try 2 VW flat fours joined at the crank. Not a single common crank, just joined together. If you want extra weirdness points, try one on top of the other instead of end to end....
In reply to Conquest351:
Falconer V-12.
Lycoming IO-720 for that Porsche vibe.
needs an LS of some flavor... LS9, perhaps?
I believe we have a winner. With turbos or a centrifugal period looking blower bolted directly to the crank. Are these engines redily available or are they one of those obscure non findable engine?
fanfoy wrote:
V8? Check
Air-cooled? Check
We have a winner!
Dumb question of the day, what is this?
