6 7 8
Stampie
Stampie MegaDork
10/19/24 11:41 p.m.
In reply to java230 :
What's bringing you down?
java230
java230 PowerDork
10/21/24 2:22 p.m.
In reply to Stampie :
Sister In Law is graduating college. Shes at Embry Riddle.
Leftover pvc walkable membrane from a work project. Plywood floor finally will be kinda water resistant. Did not bring enough glue....
Down to 32 overnight. Fall is here.
Working on the last few projects while I can walk....
java230
java230 PowerDork
10/21/24 8:08 p.m.
I need to finish my trailer so I can go pick a big old crate up. Been wanting to do this for a long time (was going to build my own) but found this unit used on marketplace for a good price.
java230
java230 PowerDork
10/24/24 4:43 p.m.
Woodstove for a sauna showed up. Not a bad little unit. Especially for the price. Gonna have to feed it tiny logs often though.
Lit it at the shop to burn the paint off
java230
java230 PowerDork
10/25/24 4:38 p.m.
Finally finished off my new trailer (it's been in my shop for months) came out well, but heavy. 6x10 heavy C frame, 6k axle, 2x decking.
I would guess ~1k for the trailer. I was told 1100 for the crate, but after opening I'm betting it's more. Bottom half is solid wood. And there is a bunch of asphalt shingles too....
Indy - Guy
Indy - Guy UltimaDork
10/26/24 2:38 p.m.
I've never seen a trailer tongue like that before.
How does it function?
java230
java230 PowerDork
10/26/24 3:41 p.m.
In reply to Indy - Guy :
I have built a few like this. 2" square tube with a coupler on it, slides into receiver. Easy to make theft resistant if you remove the coupler.
java230
java230 PowerDork
10/27/24 2:07 p.m.
Second hitch pin goes thru the coupler
java230
java230 PowerDork
10/27/24 5:43 p.m.
Flattened a spot out, threw down 2 RR ties and started building. It's level ish (about 1/4"). I figure things are going to move a bit anyway.
Add front and rear walls and continue around. Nailing every other one.
Exterior done! Glacier approved.
Interior was pretty easy as well. The whole kit went together way faster than I expected. About 6 hours.
Scrap of a counter top, and a piece of stainless plate I had kicking around d makes a spot for the stove.
grover
grover Dork
10/27/24 10:27 p.m.
I've seen those advertised a lot. Looking forward to hearing how well it works.
java230
java230 PowerDork
10/27/24 10:41 p.m.
In reply to grover :
I have too. Found this as a return on marketplace. It assembled way better than I ever expected. 6 hours Incl the borrowing of a tractor from the neighbor the level out the area. I could have fired it Friday, but it was getting late.
Using a capybara stove.
I didn't realize my wifi temp sensor topped out at 140. I just kept adding wood and wood and wood.
Works good IMO! Did a cooler session yeatersay. 130ish.
Indy - Guy
10/28/24 7:31 a.m.
Oh, that makes sense yes
6 7 8
Zt4OAXaVhpb2wo8DzJY0YNbGAQ0MLdaNhEhyr0YNmhccBWJ0RADMzuLWrC1HxOy7
