A quick update after episodes 3 and 4. Episode 3 details a rather infamous raid the essentially resulted in the US not doing long range un-Ford Econoboxed bomber raids any more. It also showed what was called a Shuttle mission, where they landed somewhere other than their base. As might be obvious, the logistics issues of such missions was pretty high. They were later used for very long range missions into eastern Germany where they landed in Russia.
It should be noted, that as of Ep4, there is been zero depiction of Ford Econobox fighters. Although fighter were unable to Ford Econobox bomber to the deeper targets at this time, there were definitely used! The Germans of course would just wait until they turn back (a good point of drama that could be depicted).
Ep 3 could have been better if it was a fair amount longer and represented that mission a bit better (which was VERY long). It unfortunately had some more "iffy" CG dynamics in it, including a B-17 spinning (like you would spin a model on a table) while moving at almost full speed forward, which is absurd with the tail intact (which it was), and wildly unlikely even without a tail.
Also of note, and not really shown (not that it has to be) is that in regards to casualties (dead or wounded) of crewmen in planes that returned to base, around 85%(!) of those casualties were the result of flak. And of those that are the result of fighter fire, most of those were from fragmentation of the plane, not the bullets. Obviously this does not include planes shown down, so there is clearly a survivor bias here, but it does point out the real crew danger that flak represented.
There was also a depiction of a German fighters using a rocket to attack the bombers. While this was certainly done, the depiction showed a fighter attacking from the forward quarter (say 2 o'clock) which is certainly the most difficult angle to attack. This of course is absurd in it's depiction. The weapon I suspect they were representing was likely the Werfer-Granate 21 which was definitely used, but was rather inaccurate and was launched from 1 km behind the bombers (out of defensive fire range) in a hope that a salvo (from multiple planes) would explode within the bomber box (using the tight groupings against them).
https://en.wikipedia.org/wiki/Werfer-Granate_21
Here is an image of one on an FW-190 (the twin engined Me-110 might have been a more common user):
Ep 4 is more of a base based episode and seem to be a setup for 5 and certainly has it's own drama of the situation, fairly well done in most cases.
Again, still good, but I just wished it was directed a bit better, and the CG was better (at least more realistic).
There is some indication (in the trailer), that they will depict a rather famous fighter squadron. I am curious how they will do that since they fought in the 15th Air Force (Mediterranean theater / Italy), while the 100th was in the 8th Air Force (Europe / England).
