jgrewe
jgrewe Dork
3/27/24 6:44 p.m.
That sounds low for a fully charged battery. It should be 12.6+. 12.2 puts it under 70% charged. I wonder if you have a dead cell and it is over charged to 2.4V per cell.
3/27/24 7:08 p.m.
Yeah that's quite likely what's happening, I'll check the voltage and try to start it in about an hour.
3/27/24 8:55 p.m.
So I went back and checked it, down to 12.15V, I'd only ran some interior lights (mostly the LED trunk light) and operated the door locks since putting the battery in. I gave it some cranking in flood-clear mode to make sure it had more than the bare minimum to start, it gave about 8 rotations before I started to hear it slow down. Cranked again and it started in 2-4 as usual. Voltage was up to 14.1V when running.
ShawnG
ShawnG MegaDork
3/27/24 9:10 p.m.
Your charging system is working but it sounds like the battery is toast.
3/28/24 5:01 p.m.
The battery was down to 12.07V today, got it returned, no testing required. Got the last battery in the store of the same model, this one had a different case with a much-appreciated handle, it was also cheaper so I got a $20 refund with it.
bvqU7UcYWdgyI0tc6jYSfRTuh5qHGu1RTm1kOWpJlslCULejDZ2CSpA2g9UjiFYA
