Beer Baron
Beer Baron MegaDork
8/1/18 6:05 p.m.
Pallet jack was leaking. Seal around the pump had gone bad. It still worked, but was clearly leaking. (It's a Grainger 5LA79 for what that matters.)
Got the requisite seals from Grainger. Installed new seals on the pump and ram. Putting in the seal on the pump was a royal PITA to fit in. Put it back together and the thing won't lift at all. My best bet is a big air pocket in the pump. I've gone through the directed steps on how to bleed the jack though, and no effect. Or possibly I screwed something up trying to install this seal - either put it in upside down (damn thing is a Y seal, not an O-ring) or damaged it trying to install.
Any advice on how to uber-bleed this pump? Or do I just say "berkeley it" and buy a new complete pump assembly?
Dr. Hess
Dr. Hess MegaDork
8/1/18 8:42 p.m.
Well, I had a similar problem.  I had a HF "racing" aluminum jack that started leaking.  I pulled it apart and put new O ring(s) in it.  Put it all together, went through the air-bubble removal process, etc.  It would not pump up.  Nothing.  I got pissed at it, threw it in the scrap pile, went to HF and bought their top of the line floor jack.  A couple days later, I walked out to the shop, past the scrap pile, and the "racing" jack was sitting there at full height.  It worked perfect and I still use it.
So, in your case, I dunno, just say berkeley it, have a beer and look at it tomorrow.  Go through the up/down/jack stuff and if it won't work, buy a new one.
Beer Baron
Beer Baron MegaDork
8/2/18 10:13 a.m.
Fixed it. The steel ball for the control valve fell out into my oil drain pan. Fished it out and replaced it. Works perfectly now.
slefain
slefain PowerDork
8/2/18 11:00 a.m.
Back to business then I assume...
jimbbski
jimbbski Dork
8/3/18 9:22 a.m.
We used to hold pallet jack races at the food store I worked at while going to college.  After hours of course!
Daylan C
Daylan C SuperDork
8/3/18 10:09 a.m.
I'm annoyed by the square footage of the parts house I work at now. No room for pallet jack drifting.
A1hIwAjXqHlpK0muHCLs09MknAQ9BCMarJnnuLEvdOmoKO1iXWOeyKtGTtxZ9A9q
