secretariata
secretariata HalfDork
3/21/14 5:16 p.m.
Just found an old G-shock watch that needs a new battery. Looking online, all of the how to articles indicate silicone grease should be used to lubricate the seal when closing it back up in order to maintain the water resistance. My questions:
  1. Where to get silicone grease in a reasonable quantity for a reasonable price?
  2. What to do with the extra grease once the watch is sealed back up?
To be honest, I haven't looked online for silicone grease yet. My expectations are that it is available from specialty vendors in 0.1 ounce tubes for $29.95 + $8.99 S&H or at Harbor Freight in 2.5 gallon cans for $8.99.
Any recommendations from the hive?
chestertiger
chestertiger New Reader
3/21/14 5:23 p.m.
The auto parts stores usually have little packets of dielectric grease at the counter for 99-cents. Pretty sure that stuff is usually silicone.
mad_machine
mad_machine MegaDork
3/21/14 5:41 p.m.
mikeatrpi
mikeatrpi Reader
3/21/14 5:50 p.m.
Napa sells Sil-Glyde. I think you can get it at the zone / advance too.
Apis_Mellifera
Apis_Mellifera Reader
3/21/14 6:00 p.m.
Lowe's - Plumber's Grease
Kenny_McCormic
Kenny_McCormic UberDork
3/21/14 6:04 p.m.
In reply to mad_machine:
How so? Straight from the Dow Corning #4 PDS "Used as a seal and lubricant for cable connectors, battery terminals, rubber door seals, switches and rubber and plastic O rings and as a assembly lubricant for various metal on plastic and metal on rubber combinations"
bgkast
bgkast Dork
3/21/14 6:15 p.m.
Your local dive (SCUBA) shop will have it.
I use it to lubricate the o ring on my waterproof camera housing.
EvanB
EvanB PowerDork
3/21/14 6:33 p.m.
O-ring grease = dielectric grease.
mad_machine
3/21/14 6:41 p.m.
silicone is an insulator. Dielectric grease needs to pass current
secretariata
3/21/14 6:59 p.m.
I have a tube of Permatex Dielectric Tune Up Grease in the garage. Looking at the Permatex Data Sheet it contains silicone. Data Sheet
The wiki implies dielectric grease is silicone grease, but it doesn't actually come out and say it. Wiki
I think I'll just use the dielectric grease I have and see what happens.
foxtrapper
foxtrapper PowerDork
3/21/14 7:19 p.m.
Dielectric grease is not conductive.
Kenny_McCormic
3/21/14 7:41 p.m.
mad_machine wrote: silicone is an insulator. Dielectric grease needs to pass current
Common misconception, "dielectric" is a type of insulator, the pressure of the connector pins pushes through it to bare metal.
Hal
Hal SuperDork
3/21/14 7:50 p.m.
Apis_Mellifera wrote: Lowe's - Plumber's Grease
plus 1 - Lowes Silicone Grease for $3.97. It's a waterproof grease that plumbers use.
mad_machine
3/21/14 8:08 p.m.
my mistake.. I was thinking of Conductive grease.. which we use on our 400amp twist lock service in the theatre.
chestertiger
3/21/14 9:17 p.m.
mad_machine wrote: Silicone Grease is not dielectric grease.. two totally opposite things. http://www.seton.com/loctite-silicone-lubricant-ee149.html?keycode=WS0194&mkwid=ks5YxbDx&pcrid=34843406882&pdv=c&gclid=CMqtuZ7ZpL0CFUNo7AodMy0Akg
Maybe we are talking about two different things, but...
http://solutions.3m.com/wps/portal/3M/en_US/Marine/Home/Products/Catalog/?PC_Z7_RJH9U5230GE3E02LECIE20S4K7000000_nid=1L4D5DCT34gs4JS4WF0WC6glTZ5RSNPDSLbl
EDT
EDT New Reader
3/21/14 11:23 p.m.
+2 for Lowes
Spuzzum
Spuzzum New Reader
8/23/19 12:56 p.m.
I've used my {Mad Paddling Skillz} to grease up the waves of old Gitche Gumee
aircooled
aircooled MegaDork
8/23/19 1:36 p.m.
Timely reply..... 4 YEARS LATER.
Clearly Canoe grease (reported).
JVFtNFHnZsRtgZxcURmGsGYFW5fuMO4CmMpgvlFgH2F75xEeyrAw533MG3OIA4B6
