dean1484
dean1484 MegaDork
9/28/22 4:22 p.m.
I was trying to detune the RX7 I found, which is harder than you think.
It may be a case where we just bump the power in the 944-cup car a little and call it good.  I started running 1:55's in the RX and through careful power reduction of the power curve so as to not change the car's dynamic I pulled it up to mid to upper 1:58s.  I need to re-test the 944 and see its times.  I think I was running 2:00 dead as the best lap so maybe add a little to the 944 and we could have some relatively even cars.  I need to replace the tires on the RX7 as the tire model on it is very old.
I will see about uploading the RX I have been working on to the Google drive and see what you all think.  Another option is to just add some weight to it but I hate to do that.  I would rather work with either the turbo boost or the power numbers.
dean1484
dean1484 MegaDork
10/3/22 9:04 a.m.
So what is the plan this week?  Start the Porsche series?  I will be comming in cold as I am away so no practice or set up.
We can go with the 1500 or the 356 or?  We will also need a track.
dean1484
dean1484 MegaDork
10/3/22 9:08 a.m.
Any volunteers to put together a track list?
We have not tested the 917
There was also the little open wheel car we tested. Is that on the table?
Racebrick
Racebrick Reader
10/3/22 9:25 a.m.
When we talked about driving the 917, nobody wanted to drive it. Let's just use the 944 cup cars and pick a track
ProDarwin
ProDarwin MegaDork
10/3/22 9:51 a.m.
Here is 4 weeks:
944 Cup @ VIR
944 Cup @ Mid Ohio
944 Cup @ Watkins Glen
944 Cup @ Summit Point
Those are all tracks that the east coast 944 Cup runs on the east coast.
dean1484
dean1484 MegaDork
10/3/22 10:59 a.m.
Done!!!  Let's do it!!!
dean1484
dean1484 MegaDork
10/3/22 11:02 a.m.
Air is going to have to come up with some new art!!!
dean1484
dean1484 MegaDork
10/3/22 11:03 a.m.
So spec 944 cup cars.  Should be fun. They are good cars!!!
dean1484
dean1484 MegaDork
10/3/22 7:41 p.m.
The question is will the tune be locked in the 944 or will be allow tuning?
ProDarwin
ProDarwin MegaDork
10/3/22 8:04 p.m.
Whatever is currently open on the UGRM 944 Cup (I don't think its much).  I can open up some of the ranges if needed (tire pressure, toe).
Also I put an update for the 944 and RX7 up on the drive (and posted in Discord).  They are pretty well balanced, but I still want to do further testing before considering a series with either.  The RX7 now has the TII Body with the wheels from the "tuner" car.  I spent a bunch of time fixing textures and I believe the only ones I have left to fix are the instrument cluster - then create a canvas for some racecar style graphics instead of solid colors or tuner crap.
dean1484
dean1484 MegaDork
10/4/22 10:55 a.m.
Whoa. You are getting really good at modding these cars!!!
aircooled
aircooled MegaDork
10/4/22 10:30 p.m.
This Week?
dean1484
dean1484 MegaDork
10/4/22 11:40 p.m.
Colin did you get the shirt?
dean1484
dean1484 MegaDork
10/6/22 7:21 a.m.
That was good racing last night.  I was so slow at that track.
And to make it official there is another T shirt up for grabs for the winner.
aircooled
aircooled MegaDork
10/6/22 2:05 p.m.
Results.
dean1484
dean1484 MegaDork
10/6/22 5:18 p.m.
 I would HC this series at 4.  Why not?
dean1484
dean1484 MegaDork
10/6/22 11:36 p.m.
Retired the G27 and put the G29 on the pc.  What a huge difference!!!   There was something wrong with my G27. I suspect I broke the brake peddle.  The other interesting thing is I was using the Logitech profiler as the driver/controller for the wheel. With the G29 I am running it through GHUB.  It seems to work much better.
Now I need to reconfigure all the settings but so far it is much better.
aircooled
aircooled MegaDork
10/7/22 12:35 p.m.
Updated results with HC.... gotta slow that Colin down....
dean1484
dean1484 MegaDork
10/7/22 1:46 p.m.
laugh
e30Matt
e30Matt SuperDork
10/7/22 10:20 p.m.
So what is the HC?
dean1484
dean1484 MegaDork
10/8/22 10:28 a.m.
Probably 25 or 30 kg. In that range. What do you think?
dean1484
dean1484 MegaDork
10/9/22 9:52 p.m.
I am going to try a modified HC system.  BUT This means we will hopefully be running this series for more than 4 races.  OR we could change over to the RX7 after 4 races but carry the HC with us.
Anyway here is my proposal. We start at a 30KG for HC #1 and decrease it by 5KG as you increase in HC level untill we get to an add of 10KG and we keep adding 10KG after you reach a total HC of 100KG
1 HC = 30kg
2 HC = 55kg
3 HC = 75kg
4 HC = 90kg
5HC = 100kg
6HC and above we just keep adding 10KG Per HC
I want to try this as there is a turning point with every car that when you add that big HC the car falls off a cliff performance-wise.  I always thought this was not optimal.  I am hoping that this prevents this while still slowing the leaders down but in a more controlled manner.
What do you all think of this idea?
We also need to agree on how HC is removed.  Unless someone says otherwise I am going with if you finish in 4th or lower you get one HC removed.
A DNS does not remove HC.
dean1484
dean1484 MegaDork
10/9/22 9:52 p.m.
I am testing tonight on the server to get the feel of my new wheel and peddles.
e30Matt
e30Matt SuperDork
10/10/22 6:55 a.m.
Sounds interesting, I'm curious to see how it works. That said, I'm out this week as I'll be in Air's neck of the woods* for work.
*disclaimer: Cali is a big state, no idea if where I'll be is in any way close to him.
dean1484
dean1484 MegaDork
10/10/22 9:40 a.m.
If I remember Air is in southern Cali
QAqmruNleBdXbIzbEz4ug5BmowUfR9qPX33lXExEF1vRSS2u37a2aiQ16aBertTs
