Antihero
Antihero SuperDork
7/7/19 7:37 p.m.
Today we went to Fantastic Caverns, pretty cool place
Antihero
Antihero SuperDork
7/8/19 6:59 p.m.
We have arrived in Hutchinson KS. Rampage ran good although it is leaking oil more than I like, 1qt every 100 miles, I'm considering adding something thicker than 5w30 in the middle of our voyages.
Indy-Guy
Indy-Guy UberDork
7/8/19 7:29 p.m.
Keep an eye on the oil level and send it.
Antihero
Antihero SuperDork
7/8/19 7:35 p.m.
Pretty much what I'm doing lol
It has high oil pressure when it first starts so it's kinda why I'm not just dumping in 20w50 in right away
californiamilleghia
californiamilleghia HalfDork
7/8/19 7:35 p.m.
still leaking out of valve cover or other places too ?
Stefan
Stefan MegaDork
7/8/19 8:06 p.m.
In reply to Antihero :
I've always run 10w30 on my Turbo-Dodges.  Didn't help the leaks, only replacing the old hardened seals and bad hoses tended to fix that.
If you can identify where it is leaking, then perhaps you can stem the tide a bit.
Antihero
Antihero SuperDork
7/8/19 8:29 p.m.
It seems to be leaking from the front of the engine although much much less than it was.
I'll retorque the valve cover again, it's been thru a few heat cycles now
Antihero
Antihero SuperDork
7/8/19 8:36 p.m.
Dead_Sled
Dead_Sled HalfDork
7/8/19 9:10 p.m.
Yes!  laugh
(Assuming you didn't break down there)
TRoglodyte
TRoglodyte UltraDork
7/8/19 9:31 p.m.
This Is How the West Was Won
Cooter
Cooter SuperDork
7/8/19 10:10 p.m.
Make sure you haven't blown out the seal at the end of the camshaft.
Antihero
Antihero SuperDork
7/8/19 10:58 p.m.
Dead_Sled said:
Yes!  laugh
I didn't thankfully lol
It is about a block away from the hotel, and it's a great place to eat
Antihero
Antihero SuperDork
7/8/19 11:01 p.m.
I don't *think* it is but frankly oil was everywhere after the first valve cover gasket blew. There isn't much oil at all inside the plastic cover either, but I'll check again
volvoclearinghouse
volvoclearinghouse PowerDork
7/9/19 7:38 a.m.
Missed a couple of pages here, traveling myself this week (To Milwaukee, on business) but I'm glad to hear the Rampage is back on.
To bastardize Led Zeppelin, Rampage On.
yes
Ashyukun (Robert)
Ashyukun (Robert) UberDork
7/9/19 8:06 a.m.
I'm glad there at least haven't been more broken studs! Hopefully re-torqueing the cover will help with the oil. I'm trying to remember what else on the front of the engine could be leaking. The only thing that comes to mind would be to check that the sender for the oil pressure gage's line is snug...
Stefan
Stefan MegaDork
7/9/19 11:11 a.m.
The dipstick tube likes to spit oil if there is pressure in the crankcase due to blow by or a non-working PCV system (though you tend to notice the dipstick sitting out of the holder when you open the hood).
The distributor has a seal on the block where it slots in and is driven by the intermediate shaft and turns the oil pump, those get old and dry out.
The oil distribution block at the front of the motor where the pressure switch/sender and oil feed for the turbo, which down and to the right of the distributor.
Camshaft end seals.  They can get old and fail.  Othertimes people put the wrong ones in (they are different for front/back) and they'll stay sealed briefly but then start leaking fairly quickly.
The only other culprit, and its a E36 M3ty one, the head gasket could be leaking as the oil feeds to the head are at the front of the block with the drains at the back.
I would hit the front of the motor with some brake clean to wash down the oil and see if you can find new sources for it later.
Antihero
Antihero SuperDork
7/9/19 12:07 p.m.
The main leak seems to be on the front of the engine, so passenger side and towards the firewall.
I tightened the stud a tiny bit above it and it looks like it stopped leaking on our small voyage to the Cosmosphere....which by the way is berkeleying awesome!
Antihero
Antihero SuperDork
7/9/19 12:18 p.m.
jfryjfry
jfryjfry Dork
7/9/19 12:21 p.m.
Don’t be afraid to stop by my father’s place to get a good look at the stud situation.  He’s very intelligent and good at digging into problems and figuring out causes of them.
Antihero
Antihero SuperDork
7/9/19 4:59 p.m.
So far, knock on wood, the studs are holding and haven't loosened at all. FWIW the new studs seemed much more substantial
And thank you for reaching out to your dad, he sent me an email with his contact info
Antihero
Antihero SuperDork
7/9/19 4:59 p.m.
This just in from the Cosmosphere.....
Indy-Guy
Indy-Guy UberDork
7/9/19 6:45 p.m.
I'm really enjoying the pics along the way, and happy you're Rampaging on!
Antihero
Antihero SuperDork
7/9/19 7:04 p.m.
Apparently the rampage didn't read that because now I have a no spark situation. Replaced the coil and got nowhere
Stefan
Stefan MegaDork
7/9/19 7:45 p.m.
Cycle the ignition on-off-on three times and count the blinks for the engine light.  That will provide trouble codes for the ECU.
I suspect its the distributor pickup, which is a common failure point.
This website should help with troubleshooting:
http://minimopar.net/
Rons
Rons Reader
7/9/19 7:45 p.m.
If I owned a Rampage I’d have to name it Randy in honour of https://en.m.wikipedia.org/wiki/Randy_Rampage
7IBynS2OA1P0ysZM0vRlKuqrBqrPRffMVm6EQ3EmEnousuKpX7WfRxCvGsf94NdO
