Project 2002: Engine Assembly
Per
Update by Per Schroeder to the BMW 2002tii project car
Jan 18, 2012
Per installs the new rings by hand.
Our trusty ring compressor gets a workout.
A new MLS head gasket from Ottoco does the trick.
We're nearly done with the engine build.
The rings were installed on the first-oversize pistons by hand; then, with a ring compressor, we tapped the pistons back home into the block.
With the new piston rings in hand from Ireland Engineering, we quickly got to work reassembling our BMW 2002’s engine. The rings were installed on the first-oversize pistons by hand; then, with a ring compressor, we tapped the pistons back home into the block.
From there, the process went quite smoothly: We used Ottoco MLS multi-layer head gasket, which doesn’t require retorqueing. It’s great that we can use modern technology in our 40-year-old engine. With the head on, we set the valve clearances at .008-inch with a feeler gauge and took care of the rest of the assembly, including the Kugelfischer mechanical fuel injection.
Next up—installation!
Do you like web updates like this? Get the whole story on all of our project cars in the pages of Classic Motorsports magazine. Subscribe to Classic Motorsports today!
Sponsored by
Bavarian Autosport
TvmTil9tdxXswPAK9XEbnGuVBnuNqbKLje2fPkSxxj7WRywZ4t8BwR3xFY3LRo6s
