Video: How to rebuild an entire front suspension
https://www.youtube.com/embed/-V0ULy-R0_c
The front suspension of any car contains numerous moving parts that can, and will, degrade over time–and our 1960 Austin-Healey Sprite project car is no different.
Here's how we rebuilt our Sprite’s front suspension while adding a few proven upgrades.
Presented by CRC Industries.
Recent videos
59WhiteBugeye
59WhiteBugeye
8/5/21 12:38 a.m.
In reply to ChrisTropea :
I'm in the process of a Bugeye restoration. You mentioned shimming the front shock to give 1 to 1 1/2 degrees negative camber.  How thick should the shims be? This seems like a cheaper way to get the same results.  Thanks, in advance.
Tim Suddard
Tim Suddard Publisher
8/5/21 7:41 a.m.
In reply to 59WhiteBugeye :
I think the answer might be both. Our springs were shimmed nearly an inch, which is way too much. I would say 1/4-1/2" is more appropriate. The offset bushings are inexpensive as well.
dug
dug New Reader
12/25/23 11:36 a.m.
If I remember correctly disc brakes were an option on MK1's. They were not the Lockheed brand but Dunlap. The option of discs was so expensive only a handful were sold.
Very rare.
Dug
You'll need to Log in to post comments.
More like this
jP7bMZIWSwvQISxbzgClQ3WTJioTmsxQvG9wGSfsqQscmrNOimcFuJh29j1KfvUv
