34-point road trip checklist
Carl
Photography Credit: Chris Tropea
Before hitting the open road for your next adventure, take the time to give your car a mechanical once-over.
Brakes and Suspension
  • Hand brake works properly-can safely slow the car, hold the car on a hill, and release completely.
  • Pedal free play is properly adjusted.
  • Brake pedal has no sponginess and never requires any pumping.
  • No pulling in either direction.
  • No inappropriate lockup under hard braking.
  • Shock absorbers work correctly.
  • Ride height is correct.
  • No binding, especially the anti-roll bars.
  • Wheel bearings are lubed and adjusted properly; all split pins are installed.
  • Suspension and steering are lubed.
Exterior
  • Panel gaps are appropriate.
  • Doors latch properly on primary and secondary latch points.
  • Hood and trunk releases are adjusted, tightened and lubed.
  • Door handles, bumpers and any other bolt-ons are tight and rattle-free.
Interior
  • Seat belts work properly and are new enough to be safe.
  • Seats slide freely.
  • Gauges and dash lights work.
  • Mirrors hold adjustment and don’t rattle.
  • Steering wheel is on straight.
  • No unplugged holes in dash.
Electrics
  • Battery is tied down.
  • Horn is loud and works every time.
  • All lights and accessories are operational.
  • Charging system works and belt is tight.
  • Proper fuses everywhere.
  • No dangling or unterminated wires.
Engine and Drivetrain
  • Compression is within 10 percent on each cylinder.
  • Good oil pressure-minimal or no leaks.
  • Proper oil level in engine, gearbox and rear axle.
  • Engine idles well and at a consistent rpm.
  • Car accelerates smoothly.
  • Engine shuts off without dieseling.
  • No exhaust leaks.
  • Coolant is completely topped off and no air bubbles are present.
Join Free Join our community to easily find more Porsche, Road Trip and Tech Tips articles.
300zxfreak
300zxfreak Reader
9/3/23 11:20 a.m.
Very timely, I'm just about to embark on a backroads trip from Ohio down to South Carolina, good things to think about and check beforehand.
9/6/23 2:09 p.m.
In reply to 300zxfreak :
A stitch in time and all that.
Safe travels!
Mhumphries
Mhumphries
7/17/24 1:59 a.m.
If you are really going on a road trip you need more on your list than that. I do several multi day vintage rallies every year in a 67 E Type Jaguar and a 73 TR6. Most of our old cars we would be using on a road trip are at least 50 years old. A lot of things that seem ok but are on the verge of breaking under the kind of conditions a typical road trip produces.
A smart road tripper in a vintage car needs:
A small tool bag with sockets, wrenches , wire cutters, screwdrivers and pliers
a roll of duct tape
a small roll of tie wire
spare rotor, condenser  and points
assorted fuses
a couple of spark plugs
2 quarts of oil
spare tail and stoplight bulbs
a spare fan belt
light leather gloves to handle hot parts like a muffler
a couple of shop rags
small container of hand cleaner
some spare insulated electric wire 16-14
a few wire nuts for quick electrical repairs
a hidden spare key
pk3I0kqPxRKmrEecw2fFLyV93Pxbdfr3TGumA3lUBOWFVXVPaIyDfYBK9296LB91
