A closer look at scoops on vintage race cars
David S.
Photography by Tom Suddard and David S. Wallens
Today, scoops are often a design trick used to imply speed and performance. In some cases, their only function is cosmetic. Originally, though, scoops had a simple purpose: to help get air in or out of the car.
Working on a project and want to see how those before you did it? Here are some examples.
As an added challenge, how many of these cars can you identify by their scoops alone?
Join Free Join our community to easily find more Air Scoops and Design articles.
dougie
dougie Reader
3/6/20 11:00 p.m.
Oh, please.....don't forgot the Big Healey!
3/15/20 9:47 a.m.
The first one looks like an old swamp cooler.  Wonder if it's more effecient if you add ice.
Jpsbgt
Jpsbgt New Reader
9/25/21 1:56 p.m.
That is not an air scoop on the Cunningham ! It's a oil cooler.
aircooled
aircooled MegaDork
9/26/21 9:21 p.m.
Looks like it might be a re-purposed aircraft honeycomb style oil cooler.
mcloud
mcloud New Reader
2/2/25 12:57 p.m.
Liked Tom's article on installing hood louvers to extract hot air.  Will try that on my 1971 VOLVO 142 vintage racer.
mcloud
mcloud New Reader
2/2/25 12:57 p.m.
wspohn
wspohn UltraDork
2/3/25 10:44 a.m.
I ran in a vintage class that banned the addition of any added air passages.  After thinking about it a bit, I just installed longer pins for the rear bonnet attachments of my MG, with two holes drilled for the retaining pins.
Going through tech?  Just put the pins through the lower holes and sail through with no issues.
Before going out on the track to race, put the pins in the upper holes - still looks right to any scrutineers watching you go out on the track.  Then on the track at speed, the rear of the bonnet lifts with the air pressure underneath and exposes a nice fat slice of exit space for the air that wants out from under it.  Worked well and dropped under bonnet temps quite a few degrees.
My other aero trick was inspired by the rules failing to specify any minimum ground clearance for front air dams/spoilers.  I made up a lower air dam section out of canvas/rubber conveyor belt material - it could actually touch the pavement under maximum braking but being flexible was quite long lasting.  By having the air dam closer to the track surface I picked up about 500 rpm at the end of the straight
yVfPvYOEmCl6GpQor4EBruQQSjKwEHZN7aWiA5pkUoRfr4dE1DM5XklIrnhgRaED
