Off Our Rockers, New Sills for This Old MGB
Carl
Story and Photos by Carl Hiedeman Some people are lucky enough to live where the sun shines all the time. For the rest of us, we get to deal with rust every now and then. The trouble is, it’s getting harder and harder to find body shops that will fix rust anymore. Fortunately, if you’re the type that likes to do a little work yourself, some rust repair projects aren’t really that hard if tackled methodically. One of the most common places rust materializes on British and Italian sports cars is down in the rocker panels—also known as the sills. Low on the car and always in the elements, these sections of the body are quick to fill with dirt and moisture, a lethal combination for steel. Rusty sills are not only ugly, but since they’re often also structural problems, they can quickly lead to sagging doors and a flexing body. As bad as all this sounds, the repairs are pretty straightforward. With quality replacement parts available and the advent of lower welder prices, sill replacement can be a weekend job. We’ve made this repair hundreds of times and thought we’d show you how we do it. Follow along as we replace the right-side rocker panel on a 1978 MGB.
1.
None
While it appeared that our 1978 MGB only had some bubbling in the lower areas, we knew that the damage was more than skin deep. This car had serious rust in its sills.
2.
None
Once the car was in the shop, we removed the front fender so we could access the front section of the sill. In order to remove the fender, we had to remove the windshield. We also took off the front bumper to gain a little more working room. Lying in the foreground is our new rocker panel and inner section—about $180 in parts. We didn’t end up needing the inner section. (Note: Some people will cut away the lower portion of the front fender since it often needs to be replaced, as well. We prefer to remove the whole fender; while a little more time consuming, it allows us to get better access to everything.)
3.
None
The next step is critical. As we prepare to cut off the old rocker panel, the car will lose some of its structural integrity. This is why we only work on one side of the car at a time. We have found that carefully jacking up the car by the side and supporting it at an angle not only gives us great access for these repairs, but it helps us make sure all alignments are correct—more on this later.
4.
None
Once the car is in the air and secured on jack stands, the extent of the rust damage is clear.
5.
None
The entire panel is bad: Small holes have formed up front.
6.
None
After cutting away the dogleg section, we found some serious rust in the rear section of the rocker panel. Good thing we planned on replacing the whole thing.
7.
None
The rocker panel was spot welded in place at the factory. While many people will drill out every individual spot weld, we’ve found this too time-consuming for our taste. Instead, we used a die grinder to remove the top layer of the spot welds, thus weakening them. Then we used an air chisel to split the rusty rocker panel away from the panel beneath.
8.
None
The panel can then be cut free from the floor. We’re using a sharp blade made especially for panel cutting, not a chisel bit intended for snapping nuts and bolts.
9.
None
On this car, we found that the inner sill was in excellent condition and didn’t need our replacement panel. We simply cleaned it with a wire brush and sprayed on some rubberized undercoating.
10.
None
Here is our next critical step. We clamped the replacement rocker panel into position and then reinstalled the front fender. We adjusted the panel to fit the door and made sure the door still properly fit inside its opening. It wasn’t necessary on this one, but sometimes we’ll need to move the rear jack stand to slightly flex the car in order to get the correct rear door gap. Moving the stand forward will increase the gap, while moving it backward will decrease the gap. While some people will brace the door openings, we’ve found this to be unnecessary—in fact, a brace can even be a disadvantage. If the car was previously sagging, the brace could “lock” the sag into the car.
11.
None
Once we were happy with the way everything fit, we removed the fender and replacement rocker panel and prepared for welding. Since we’ll be using the rosette weld process—also called plug welding—we punched a series of 5/16-inch holes about 11/2 inches apart on our rocker panel. We then ground the areas directly around the holes to bare metal for a clean weld. Don’t forget to apply some undercoating to the inside of the panel, and everyone seems to have their favorite. Rubberized undercoating is popular since it’s easy to apply, but it’s also flammable and can cause rust issues if it’s allowed to plug drain holes. A wax-based product like Eastwood’s Heavy-Duty Anti Rust is a great solution.
12.
None
We used this punch/flange tool to punch the holes. (Eastwood and other restoration supply houses sell the tool for about a hundred dollars.) Alternatively, we could have drilled them with a 5/16-inch bit. If you’re buying a punch tool, make sure to get the one that punches a 5/16-inch hole. Some units on the market only punch a 3/16-inch hole, which we feel is too small.
13.
None
Our HTP MIG 140 welder has been a workhorse for this type of project. Operating on a 20-amp, 110-volt outlet, it will weld steel up to a quarter-inch thick. In our case, it’s more than up to the task for this sheet metal.
14.
None
Rosette welding is very easy to master. A 5/16-inch hole is punched or drilled in the top piece to be welded (right). Then, the hole is welded shut (middle). After grinding, it’s nearly undetectable (left).
15.
None
With the rocker panel clamped back into the previous position, we began to rosette weld it into place. Once all the welds were finished, we ground them smooth. In the end, the panel looked like it had been there all along. We’ve still got work to do, like replacing the dogleg and repairing the bottom of the front fender, but at least we’ve restored the structural integrity of our MGB.
Five Common-Sense Welding Tips
While some people want to make rocket science out of welding and others treat it like black magic, we find common sense is our best guiding principle when it comes time to fuse metal to metal. Here are five common-sense tips to live by when you’re welding: 1. If you can’t see, you can’t weld: Wear a good quality helmet—we prefer the auto-darkening style. Once you have your helmet, make sure you can see what you’re welding. You might need to adjust or thoroughly clean your lens. You’ll also have to train your eyes to see what’s important in the weld. Two things are vital: the line along which you’re supposed to be welding and the quality of the puddle. If you can see where you’re going and “read” the puddle to make sure it’s the right temperature, you’ll find your welding greatly improved. 2. You can’t weld dirt: Cleanliness really matters in welding. You can only weld clean, bare metal—not rust, paint, dirt, scale or any other contaminant. Do everything you can to keep the weld joint clean, and it will show in your welding. While you’re at it, make sure your gloves and your welder are also spotless—dirt on your equipment can end up in your weld. 3. Use both hands: Good control makes for good welds. While you can technically MIG weld with one hand, using both hands gives you more control. Some people hold the torch with both hands, while others will use their non-dominant hand as a guide. Either way, you’ll weld better with two hands than one. 4. Read the instructions: Welder setup is key to weld performance. Read your welder’s instructions and make sure you’ve got everything dialed in correctly. Most welders have a chart that explains which voltage and wire speed are needed based on the material, thickness and gas. While asking for directions might not be your thing, it’s the best way to get to where you want to go: good welds. 5. Be comfortable and in a good mood: When’s the worst time to fix a burned-through hole? Right after you screwed up and made it. Comfort and mood make a huge difference in your weld quality, so be happy and cozy when you work. Think about it this way: If you’re crouched down, you’ll be thinking more about your sore knees than your welds. As a result, your welds will suffer. Try sitting on a small chair or a milk crate to get comfortable.
Tools For The Job
While there are a few specialized tools for a job like this, there are still some ways to get by on a budget. At minimum you need safety gear, a welder, grinder, tape measure, snips and common sense. As far as the safety gear goes, you’ll want some good, nonflammable gloves, a full face shield and ear protection. We also highly recommend steel-toed boots, some long pants a tight-fitting, long sleeve shirt. There are a lot of good 110-volt MIG welders on the market these days. While we find that the $200 machines don’t cut it, most of the units in the $500 to $700 range are great choices. Get one that uses shielding gas, as it’s a great improvement over flux core. If you don’t want to step up to a new one, your club or a friend might have one to loan. You could also rent one or purchase a good used unit—they’re out there. Grinding and cutting will be a big part of your job, so you’ll need some tools for this. We like air-powered straight and 90-degree die grinders, but since decent ones are usually around $100 and require a big compressor, you might want to consider an electric unit. Name-brand 4-inch grinders usually cost about $80 to $100, but if you want to go cheap, the discounters will have them for as low as about $20. If you’re only going to do this job once, the budget units might last long enough for you. Regardless of what you spend on the grinder, make sure to buy quality abrasives. At 20,000 rpm, you don’t want a grinding disk to shatter and send shrapnel through your neck. Once you’ve got a grinder, get a name-brand pair of aviation snips. We like those from Wiss or Irwin and can usually find them for about $15 to $20. Finally, round out your tool kit with a tape measure and some common sense. From time to time you’ll need to figure out why components aren’t fitting. Instead of beating or yelling things into place, follow a more scientific approach and take measurements. For example, when we install sills, we measure that the left and right door openings are about the same. We also take cross-measurements of the cowl to make sure the car isn’t tweaked. The tape measure will tell you what’s wrong and where much more quickly than all the banging and screaming in the world. Use your common sense, take your time and you’ll find it’s not that hard.
Join Free Join our community to easily find more MG articles.
tr8todd
tr8todd Dork
6/16/18 5:21 a.m.
Ah shucks, thats nuthin.  Most of the Bs here in the Northeast need inners, outers, middle truss section, castle rails, floor patch panels and lower fenders at a minimum.  Thats exactly what I did on my first big welding/body restoration.  Sounds difficult, but was actually pretty easy and very rewarding.  Except for the whole welding slag falling into your boot thing.  Love the article.  This is the kind of stuff I love about this place.
wspohn
wspohn Dork
6/17/18 10:48 a.m.
Another reason I prefer the MGA - sure the outer rocker panels corrode, but they aren't structural and the frame is overbuilt and doesn't usually have rust issues anywhere near as bad as the MGBs.
Well, that and the fact that the MGAs look so much better than the MGBs..  devil
MustangSix
MustangSix Reader
6/21/18 8:16 a.m.
Great tutorial.  How long did the job take to complete?
Tim Suddard
Tim Suddard Publisher
6/25/18 7:01 a.m.
MustangSix, you can usually do sills in a day or certainly a weekend.
NOHOME UltimaDork
7/4/18 1:15 p.m.
A good tutorial from the master himself. I blame Carl for much of what I know about Brit tin-work.  A full on-replacement of the entire assembly would also be good for those faced with such a task.
There is another path that I follow when I can. I call it a "Rockerectomy" where rather than replace the entire outer sill, I slice and graft a new Herritage sill on to the upper part of the original sill.
Use a cut-off wheel to make a nice straight cut the full length of the sill. Note that this method wont work for all cases.
Chop the nice new expensive Herritage sill into two pieces
One mother of a long but-weld later
The reasons for doing it this way are a bit petty: I like cars that can pass as not welded on if I can pull it off. The fist place I look is the spot-welds on the top of the sill where the a-post attaches via a small tab to the sill. Being restricted to a rosette weld, this is a hard spot to make look factory. Same for the pinch weld in the door opening.  Also the area under the front fender where the kick-panel, inner and outer sill are all sandwiched together. A lot of sill repairs leave this area in a bit of a mess visually speaking.
I also prefer a dogleg cut that leaves as much of the door sill gap intact. A diagonal cut often will work leaving more of the original parting lines in place.
I would starve if I tried to make a living at this cause I am too slow...Realistically, I would budget a month of calendar time for the first time sill-job. Not that it cant be done in a week-end, but it is not a job you want to rush the first time.
I am paranoid about twisting a car. Sagging not so much so I also skip the bracing of the doors. I do this work with the car level and supported as if it were on the tires.  If the gaps are not right, I address that before I cut. The floor in my shop was poured flat just so I could do stuff like this. Shimming the axle stands will achieve the same purpose.
Pete
JAGwinn
JAGwinn New Reader
7/4/18 8:38 p.m.
Very nicely done!
TedFlorida
TedFlorida
7/9/18 2:18 a.m.
Nice job
RVCIuKJlk2I8GPJlj4BrfEwiJ3YKbbKfO7gfcR3O94rN1THsdERUbIFfJ41NhuI7
