2 3 4 5 6
Mad_Ratel
Mad_Ratel Reader
12/6/14 11:46 a.m.
I was refering to this pic... optical illusion I guess.
aussiesmg
aussiesmg MegaDork
12/9/14 9:59 p.m.
Sampson does his first real tow, took the MGB to the PRI show, zero issues and a comfortable ride, achieved roughly 10 mpg.
Swank Force One
Swank Force One MegaDork
12/9/14 10:04 p.m.
Where the hell are you parking that rig downtown?
aussiesmg
aussiesmg MegaDork
12/9/14 10:07 p.m.
We came back home tonight, going back Friday and staying for Saturday, not parking at the venue until the car needs to be collected.
Kenny_McCormic
Kenny_McCormic PowerDork
12/9/14 10:48 p.m.
In reply to Swank Force One:
I wonder if it's ok to take up two parallel parking spots if you feed both meters.
JohnRW1621
JohnRW1621 UltimaDork
12/10/14 7:40 a.m.
Swank Force One wrote: Where the hell are you parking that rig downtown?
Just look at it and it's awesomeness.
My guess is... anywhere you dam please!
aussiesmg
aussiesmg MegaDork
12/13/14 7:36 p.m.
On way home from PRI, Parts sourced, stay tuned for updates.
Mohr Powar
aussiesmg
aussiesmg MegaDork
12/14/14 10:52 a.m.
It fits..Underground parking FTW
aussiesmg
aussiesmg MegaDork
12/14/14 10:53 a.m.
PRI booty is going in this week
aussiesmg
aussiesmg MegaDork
12/14/14 3:00 p.m.
Coming apart and getting cleaned
Can you say restriction
somewhat larger, especially flow
Toyman01
Toyman01 MegaDork
12/14/14 3:37 p.m.
Just can't leave them alone, can you.
How much gain is that supposed to net you?
aussiesmg
aussiesmg MegaDork
12/14/14 4:03 p.m.
Nope, not at all
Probably 100 hp and 200 ft lbs at a glance.
I am researching some other easy mods, including turning up the maximum RPM to 3000, increasing the fuel flow and even injectors.
Sampson pulls like a train but runs out of RPM at 2700, which is 70 mph, a few more mph would allow for passing and easier cruising speeds, more horsepower is always welcome.
aussiesmg
aussiesmg MegaDork
12/14/14 4:14 p.m.
Info
6.6L (bore 4.4", stroke 4.4"):
160 hp (49 states): 160 hp @ 2600 rpm, 378 lb/ft tq @ 1600 rpm
170 hp (49 states): 170 hp @ 2600 rpm, 402 lb/ft tq @ 1600 rpm
170 hp (California): 170 hp @ 2600 rpm, 402 lb/ft tq @ 1600 rpm
Toyman01
Toyman01 MegaDork
12/14/14 4:28 p.m.
Have you considered a larger tire. A more truck sized tire would drop the cruise RPM and probably up the fuel economy at the same time.
MrChaos
MrChaos Reader
12/14/14 5:19 p.m.
In reply to Toyman01:
that is what most of the guys with GM M1008's(Chevy K30) do, jumping to a 37" tire actually lets you do 75mph at less than 3000 rpm. 6.2 diesel + 3 speed Turbo 400 + 4.56 gears = 60ish mph max speed on stock 33"s
aussiesmg
aussiesmg MegaDork
12/14/14 7:05 p.m.
Ummm guys, look at the wheels, they are 22.5" semi wheels
The tires are low pro but the handling is worth the RPM, Clifford has full height tires
Plus tires are $400 @, so they will be a while.
The new turbo was a deal at $300 from PRI as a display model.
Mad_Ratel
Mad_Ratel Reader
12/15/14 11:53 a.m.
http://mobile.craigslist.org/cto/4800255945.html
for anyone looking for a "similar truck."
SnowMongoose
SnowMongoose Dork
12/15/14 12:07 p.m.
The only way to trump what you've got going now.
81cpcamaro
81cpcamaro HalfDork
12/15/14 12:18 p.m.
Bigger turbo is always better. I think the shorter tires look good on Sampson. Considering how close you were in that parking garage, the shorter tires do give you some options. BTW, how long is Sampson?
aussiesmg
aussiesmg MegaDork
12/15/14 3:43 p.m.
Just under 7' high, estimated 22' long.
The 6 door is only 1 ton F350, Sampson is an F600.
Turbo install is going well, note the welded repair to the crack in the exhaust manifold
MrChaos
MrChaos Reader
12/15/14 7:11 p.m.
so is a 4x4(err or 6x6 as it is a dually) conversion in the future?
aussiesmg
aussiesmg MegaDork
12/15/14 7:41 p.m.
No 4x4, this is a tow rig, not an off-road rig, 11,000lbs will not be pulled out of a mud hole easily
Mad_Ratel
Mad_Ratel Reader
12/15/14 8:46 p.m.
aussiesmg wrote: Just under 7' high, estimated 22' long. The 6 door is only 1 ton F350, Sampson is an F600. Turbo install is going well, note the welded repair to the crack in the exhaust manifold
hence the "similar". 11ft bed was the similarity part. plus also still rediculous truck.
ebonyandivory
ebonyandivory SuperDork
12/17/14 10:58 a.m.
It's funny... BroDozer drivers get ripped on (mostly on target) and this thing as well as Clifford make those trucks look subdued. But not even once do I think that way about Aussiemg or his trucks.
These trucks serve a purpose especially Sampson. So that combined with what feels like a sense of humor, makes the BroDozer crew seem even more pathetic.
Gimp
Gimp SuperDork
12/17/14 12:16 p.m.
I had a dream last night that I was riding in this truck. That's all.
2 3 4 5 6
as2DMjeOmZiJPKGu4sql6owuAclwgTqF0bPwD8UYs4fLc7vJHwcGzWC4PVeAM3j3
