Time for some quick updates!
I replaced the e-brake lines when I rebuilt the rear end and everything seemed fine, but a few weeks ago I pulled up the e-brake handle and it seemed to slip a bit and didn't grab like it was doing before, so I knew I had to get in there and adjust it. According to the 101 Projects book, I first needed to check the brake fluid level. I'm glad I did, because it was overfilled.
Much better now
I had to remove one of my Motorsport Hardware studs to gain access to the adjusting wheel:
The book said it adjusts in opposite directions on the DS/PS of the car, but mine seemed to get tighter when I turned both wheels towards the back of the car, which threw me for a loop. After some time I got the shoes adjusted and moved into the cabin to adjust the e-brake handle.
This whole process would have been much easier with a second set of hands, but I didn't have any, so I had to keep going back and forth until both sides were even and seemed to match what the book said.
Next up was the ambient temperature sensor. You may recall that I bought a new sensor since the car didn't come with one, but that didn't fix the problem, nor did unplugging the battery, so I started inspecting things a little more closely. Right off the bat I noticed what appeared to be non-OEM electrical tape around one of the wires going to the sensor. I peeled back the tape and found the problem!
And I'm not surprised it wasn't fixed. The wire broke right at the end of the rubber protective elbow, and there was nothing to grab on to. With nothing to lose, I disassembled the connector:
And cut off the rubber protective elbow:
And proceeded to do very stupid things with my butt connectors. Had I thought about what I was doing before I did it, this would have turned out much prettier, but I didn't.
Yeah, that new wire is probably going to break in five years, but for now, I have ambient temperature! This is now the fanciest car I've ever owned!
I then drained the trans fluid. It was not pretty:
It's tough to see, but there is a fair amount of metal bits in there. Not a good sign. When I took the drain and fill plugs out, I noticed there was a fair amount of teflon tape on them, which made me worry about the plugs leaking. Thankfully, I had bought this nifty stuff for my wife's Escape:
What I didn't realize was that the stuff takes 72 hours to fully cure! WTF kind of product is this? Who has 72 hours? Crap. Oh well, I'm only going to replace the trans fluid every couple years, and if this is what I need to do to keep it from leaking, then so be it. I'm going to be putting in Redline ATF tonight after this goo is supposed to be cured.
I also swapped out some of the nasty power steering fluid for some new stuff.
Now I just need to do that like 10 more times and the system will be clean!
More coming later!
