TurboFource
TurboFource Dork
9/30/24 6:56 p.m.
It ended up that one of the wires was disconnected from the ignition switch, it is kind of intermittent working so I am going to order a new one to eliminate potential near future issues. I was now able to link my iPad to my 123ignition and load my baseline timing curves. The fuel pump comes on and momentarily turning to start and I hear the starter solenoid  8)
I am going to have to get a fuel pressure regulator as the pump is putting out 3.5 psi and overwhelming the float ….  :-\
I made lightweight natural fiber brackets to mount the rear license plate as I wanted to see how it was going to look ...
TurboFource
TurboFource Dork
10/5/24 4:23 p.m.
Had to buy a bottle …..  ::)
Fuel pressure regulator and new ignition switch showed up ... first start next week ?!?
crankwalk (Forum Supporter)
crankwalk (Forum Supporter) UltraDork
10/6/24 7:17 p.m.
TurboFource said:
Looks tough. Hope you leave it straight off the turbo with no muffler at least long enough for a video. laugh
TurboFource
TurboFource Dork
10/7/24 6:19 a.m.
Current plan is the turbo is the muffler ......
TurboFource
TurboFource Dork
10/7/24 3:19 p.m.
I started off with high hopes for the day …. But now have another quote to add to the list of murphyisms.
“You are only one chinesium part away from a bad day  >:(“.
The new fuel pressure regulator I just got would not go below 3 psi even though it is rated to produce 1 - 4 psi, I even took the adjusting screw and external spring out of it completely and wasted quite a bit of time trying to make it work to no avail…
So I thought “instead of trying to control the pressure mechanically why not bleed it off with a controlled orifice (because simplify too …).
Turns out a bypass line with a 1/16” hole produced 2 psi with one pump and 2.5 psi with the “boost” pump on also, most importantly the carb seems happy with it 8)
So remember your ABCs….. anything but chinesium!
Mezzanine
Mezzanine SuperDork
10/7/24 4:39 p.m.
Nice solution. I'm eager to hear it run.
TurboFource
TurboFource Dork
10/14/24 5:07 p.m.
I was hoping for first start today …. But …. I think I had my ignition timing off, just spoke with Ed at 123 and sent him a short video of me setting static timing and he confirmed it is now correct.
On the bright side I learned -
- How to correctly set my 123 distributor (not sure how I goofed that up but I did  ::))
- That a lawnmower battery will crank over a Twin Cam for quite awhile when trying to start it with the timing off!
- That it makes 60psi of oil pressure while cranking it   :)
- Dang carb still overflowing (maybe from all the cranking?)
First start tomorrow?
TurboFource
TurboFource Dork
10/18/24 8:01 p.m.
My Mighty Vac died so I went get a new one and discovered they are now chinesium so I bought a different brand that does both vacuum and pressure. So I decided to check my fuel inlet valve with the pressure from it to discover that the valve wasn’t leaking but it was leaking between the aluminum sealing washer and the carb body (used soapy water)! The washer is flat so I figure the unmachined surface that it seats on isn’t flat.  I am going to try a fuel and heat resistant non-hardening sealant on the threads.
gixxeropa
gixxeropa HalfDork
10/21/24 8:49 a.m.
In reply to TurboFource :
Could also try a ptfe washer, I've used them reasonably successfully at work on pneumatics
TurboFource
TurboFource Dork
10/21/24 4:51 p.m.
It’s alive  :trophy: :beerchug: :pirate: !
Started the day off fixing carb flooding … bench checked it with pump running for 5 minutes with no issue (the sealant worked). Reinstalled my fuel pumps as I wanted to make sure there were no leaks there either (great fun to reinstall  :-\)
And it started up and ran for about 30 seconds, restarted and then wouldn’t restart …. Head scratching ensued …. Checked several things over and ended up the plugs fouled from all the oil in the cylinders from assembly … cleaned them and ran it for several minutes  8)
I have a video on my phone but no idea how to post it?
gixxeropa
gixxeropa HalfDork
10/21/24 9:29 p.m.
woohoo nice! easiest way to do a video would probably be to upload it to youtube then post a link
TurboFource
TurboFource Dork
10/24/24 6:25 a.m.
4 years ago today I bought TCST …. some how I thought I would be a little farther along than I am  ???
10/24/24 2:17 p.m.
Nice!
TurboFource
TurboFource Dork
10/24/24 3:26 p.m.
I of course tried this Monday after first start .....and it was nice!
TurboFource
TurboFource Dork
10/26/24 1:04 p.m.
TurboFource
TurboFource Dork
10/28/24 5:21 p.m.
Working on a permanent solution to my fuel bypass setup. Decided to start prepping my “decent” dash as it needs a little repair work and will probably re-clear it. Decided to pull the crummy original as I bought a new DB10 lighting relay, voltage stabilizer for the gauges and washer pump and figured I should check out the heater core as first drive will probably be in cold weather  8) Removing the demist bezels without removing the windshield was challenging! I have a new windshield but do not want to install it until bodywork is completed.
Recon1342
Recon1342 UltraDork
10/30/24 9:56 a.m.
Plywood dash?
gixxeropa
gixxeropa HalfDork
10/30/24 1:19 p.m.
In reply to Recon1342 :
It's plywood with a nice looking veneer on it. They pretty much all deteriorated and cracked rather quickly
TurboFource
TurboFource Dork
10/30/24 3:34 p.m.
In reply to Recon1342 : This one is far nicer than the one in the car! At some point I may make a brand new one but not now ...
TurboFource
TurboFource Dork
11/4/24 4:23 p.m.
The struggle continues  …. First challenge in getting the dash out was the darn interior light switch/dash bracket bolts (everything in a Lotus  serves more than one purpose ... add lightness) were rusted and required persuasion to get out, and the dash to chassis bracket bolts broke off :-\  The bolts holding the dash to body wouldn’t come loose either …. Guess it is a good thing I decided to change the dash before driving as it basically fell apart, which did facilitate removal  ??? (at the first turn who knows what the steering wheel would have done   :o )
It is out … let the fun continue …. I think I need a  :BEER3:
11/4/24 4:26 p.m.
i have no idea what you're saying.  i'm not even sure what language that is.
preach
preach UberDork
11/4/24 4:33 p.m.
In reply to AngryCorvair (Forum Supporter) and TurboFource :
I got my car in 2020 and it's not even apart much yet. Forget about the 914 that now sits in the weeds...
Perfection takes time?
Heh.
TurboFource
TurboFource Dork
11/4/24 4:36 p.m.
the language of lunatics I do believe sir!
Lof8 - Andy
Lof8 - Andy UltraDork
11/5/24 12:08 p.m.
I don't know how I've missed this thread for so long, but I just browsed the whole thing.  Great work!
TurboFource
TurboFource Dork
11/5/24 12:17 p.m.
Thanx!
wkiwTUfPXhPc1ZukdcQYXYbeJ8IGA92PzGoXocjwnjIPXr1aQYItY9aE336RXgnH
