5 6 7 8 9
Robbie (Forum Supporter)
3/16/23 12:10 p.m.
As the proud new owner of a 986, this is a dangerous thread.
jimgood
jimgood Reader
3/16/23 1:01 p.m.
Box4VIR said:
What's the overunder of these numbers being ok with the corner workers.  We'll find out in two weeks!
I'm betting they'll be fine but you could always email Jeff Hall and cc Cobetto. Their contact info is here: https://nasaracing.net/contact-us/
OHSCrifle
OHSCrifle UltraDork
3/16/23 1:52 p.m.
Did you de-skin the factory body panels and rivet the CF onto the their guts or just build up all new attachment flanges? Some of them look like they overlay the factory panels and I can't figure out how that cuts weight.
Also:  what's your current curb weight?
Box4VIR
Box4VIR Reader
3/21/23 4:43 p.m.
In reply to OHSCrifle :
The factory panels are completely gone (not just the skins).  Places that really needed metal support, like the doors, headlight mounts, etc had aluminum structures made to replace the steel.  In some cases the new carbon panels are bolted on the same way the factory panels bolt on, in other cases I had to use support rods to hold the carbon in place.  There is no longer any steel panels on the car, the steel chassis itself has also been heavily cut away, the rear is basically the frame rails and a cage.  This weekend at the track it weighed in at 2,612lbs, about a hundred pounds lighter than stock despite the twin turbo v8, full cage, 17" increase in width, fire suppression system, etc etc.  That being said the carbon body only ended up saving 90lbs :( but thats compared to the stripped body that was on it already.
Box4VIR
Box4VIR Reader
4/5/23 10:34 p.m.
First event of the season went..ok.  Pulled like crazy and all in all felt great but a improperly bleed coolant system caused a hiccup (didn't overheat just puked coolant) in the first season and then a fuse took me out of another session but otherwise it ran well...shocking.  Fitting on the trailer though is rough.  It's 80"s wide and an inch narrower than the trailer.  Very tight squeeze
next up, crank up the boost!
infernosg
infernosg Reader
4/6/23 10:02 a.m.
Glad nothing seems particularly hurt. I heard mention of head gasket and feared the worst.
Box4VIR
Box4VIR Reader
4/6/23 10:14 a.m.
In reply to infernosg :
I thought it was a head gasket.   Turns out it was an airpocket in my coolant system due to a poorly designed (by me) coolant circuit.   I pulled a bunch of air out and changed up the design.  All good, whew!
Box4VIR
Box4VIR Reader
4/10/23 10:00 a.m.
Any twin charger experts here...sigh.
jfryjfry
jfryjfry SuperDork
4/10/23 11:38 a.m.
Oh no.... what happened?
Box4VIR
Box4VIR Reader
4/10/23 12:21 p.m.
In reply to jfryjfry :
Haha, nothing.  Just going back down the rabbit hole.  I'm going to add a supercharger and go twin charged.
here's the plan.  The supercharger is a twin scroll making 30psi on a 2L.  it'll produce around 15psi on my motor I'll run another 12psi off of the turbos to get around 35psi (boost compounds between the two).   I'll run the plumping from the turbos to the supercharger to an intercooler and then to a BOV.  I might need a BOV between the turbos and supercharger.  Any feedback on the design?  The idea is to improve low end performance.
SpeedAddict502
SpeedAddict502 New Reader
4/10/23 1:41 p.m.
I have been involved with doing it on a Ford GT many times.  I would find one you can mount to the manifold and run a water cooler block under that, with your normal air to air intercoolers after the turbos.
In my experience, it only works well on roots because at the top end the turbos basically bypass the supercharger through the rotors, the boost was not adding as you put here.  To get it to truly compound I would imaging you would need a massive screw type blower that can truly ingest the air the turbos are putting out, but if you go that big on the blower you lose the bottom end again.
Just my experiences with this.
Box4VIR
Box4VIR Reader
4/10/23 2:14 p.m.
In reply to SpeedAddict502 :
Great info.   I wanted to avoid a roots blower because of the heat it puts into the air.   Sounds like if I want to stick with a twin screw I'll need a way to bypass the supercharger.
fouckhest
fouckhest New Reader
4/10/23 3:09 p.m.
I had a compound charged diesel in a previous life, made cool noises and impressive boost numbers, but was a challenge to get the system right.
With the advancemets in turbo technology in the past few years, I would expet your time, money, overall effort would be better spent on a couple newer turbos
Ando
Ando New Reader
4/10/23 3:09 p.m.
Isn't that supercharger far too small to support your air flow goals?
With a quick google I couldn't find a compressor map but this supercharger was originally designed for a pretty modest application more as an emissions cheat rather than performance.
are you planning on two of them?
Have you figured out how to get the engine to live with that boost level?
Box4VIR
Box4VIR Reader
4/10/23 4:17 p.m.
In reply to fouckhest :
Yes, very true.  I'm just having fun with the project.
Box4VIR
Box4VIR Reader
4/10/23 4:21 p.m.
In reply to Ando :
It's an interesting supercharger.  It was designed for a Miller cycle engine.  So it produced 30psi but due to Miller cycle valve overlap the engine only saw around 10psi.   My motor is twice the size so I should see around 15psi.  Originally I was going to use two, not sure I need to though.
Box4VIR
Box4VIR Reader
4/14/23 3:16 p.m.
the supercharger arrived and it "fits". It'll move over a bit to where the intake pipe is but all in all there's room.  My new plan is to use the Volvo design that uses a supercharger clutch and large bypass.   So the supercharger would only be on during low RPMs which means I avoid complex boost situations of a true twincharged setup and I can eliminate the HP loss of powering the supercharger at high RPMs.   If possible I'll set the supercharger clutch up to a pressure switch between the turbos and supercharger so as soon as that charge pipe goes from vacuum to pressure the clutch disengages and the bypass opens.  I really want to avoid compressing already compressed air, it adds a ton of heat and tuning seems impossible.
the supercharger came with a bypass, I wonder if it's big enough...probably not
Box4VIR
Box4VIR Reader
4/17/23 3:37 p.m.
Probably not worth an update but hey why not.  I've been wrestling with what to do with the back of the roof for a few weeks now.  It was a fully roof, then I whacked the back off to open up the engine.  I just couldn't get over the aero penaulty that I'm sure its was having so landed on the solution below.  I'm pretty happy with it.  It follows the countor of the roof (it doesn't buldge like the picture suggests).  I was also able to sqeeze the lexan in without removing the LED running/brake light which was a nice bonus.
DrMikeCSI
DrMikeCSI Reader
4/17/23 4:15 p.m.
Wait, supercharged turbocharged here we come. This car just gets crazier.
Box4VIR
Box4VIR Reader
4/28/23 9:35 a.m.
More plexiglass work, this time with my daughter to help me trace.  I really resisted spending the $40 on the sliding window, I was convinced I could make it myself but after seeing the finished product I'm glad I didn't attempt it and spent the money (I bought a kit from Condor made for e30s, its well made).   Next I need to tackle the drivers side which will require a frame (since that door opens).  Does anyone have any pointers on making an aluminum frame for a lexan window?  I'm thinking about using sheet aluminum instead of the AL tubing you normally see.  I don't have a welder available at the moment so that makes it a little harder.
In other news I took the car out for coffee last weekend to test out the modified cooling system, its amazing how bad Amazon radiator electric fans are compared to Spal and other higher end fans.  Do not trust the CFM claimed by what you find on Amazon.  With the new fans in place the car running nice and cool, still completely miserable as you'd expect a racecar to be on the street but its able to do it.
Box4VIR
Box4VIR Reader
5/23/23 1:24 p.m.
Well I managed to not get a single good picture at Hyperfest but I had a great time and was able to move the build forward.  I learned a few things:
1. The  boost control is not working, there is actually a wiring problem that would have caused the car to go full boost if I hadn't had also made a mistake connecting the boost lines....
2. The E85 system (which haven't tried to use) need a tweak in the program but is now up and running thanks to Marc at EFI Express
3.  The cooling system cannot come anywhere close to keeping up.  On boost it quickly gets too hot and I have to let the car cool which preventing me from running more than a couple laps and I couldn't run a full lap at full tilt.  But I was able to really beat on it for short amounts of time and everything held together which was great to see.  I'm going to add an electric boost pumps and add the stock radiators into the mix (so I'll run three rads).  This should fix the problem.  I think the main problem is the audi pump trying to handle miles of cooling lines.
Typical track day....
My other take away from the week (simply because I have a problem and can't stop) is I think I should hack the roof off.  It was, of course, originally a convertible.  I'd have to cut some of the front cage out and the windshield out, lower the seat and add some open cockpit cage adjustments to make it "safe".  Has anyone run an open cockpit car?  I think it would be a hoot.
nocones
nocones PowerDork
5/23/23 3:14 p.m.
In reply to Box4VIR :
I've ran the MG open before.  Air management on your helmet becomes a thing like on a motorcycle.  Also some track day orgs want a windshield.  But otherwise it was pretty cool.
If you could do a bolt on screen that might be a good compromise and keep street ability present.. ish.
Box4VIR
Box4VIR Reader
5/24/23 7:58 a.m.
Thanks for sharing your experience with the MG.  I guess I should check on some local laws and HPDE groups first and cut second
GIRTHQUAKE
GIRTHQUAKE SuperDork
5/24/23 10:20 a.m.
They're also very long superchargers, though they're lubricated with engine oil which is a big bonus.
The only twincharge project on here I know of, was a Foxbody turbo Mustang because the 2.3 Lima has dual spark plugs per cylinder; they used that to keep the cylinder temps low. I think they used a common Eaton M90 twin screw as the charger and it only ran up to 8PSI or so.
Outkasted
Outkasted
5/24/23 10:27 a.m.
Box4VIR, I found your thread originally on 986forum and then found this site. Great build, I have read it all. I have a couple questions i am hoping you can answer. I read what you did to widen the front but couldn't find any mention of how you widened the rear. Is it just low offset wheels? If it is can you share the size, offset and if you use a spacer? I read this is 9 in over stock, is that per side front and back? Thanks for any info you are willing to share and epic build.
5 6 7 8 9
c0MSxwD4ouEA0ge6hNhdMT5n9bMHT0lLQ2jiPqVtkslHLmVvKQGarVo2ork2Hz1x
