In reply to nocones :
We have an Elva build thread. Look at project cars updates on the Classic Motorsports site.
I've always wanted to know, do you need to flip the ring gear if you use the gearbox inverted like the Hewland gearboxes? Is the reason to flip the ring gear solely to keep the input shaft above the diff for the flat engine applications?
Looks like I am going to need a couple of early VW axles to cut down and spline. Anyone either have some, or know if I would be better to start off with new ones. While I would rather start with new, so many of the VW parts are cheap crap.
In reply to Mr_Asa :
Maybe check the technical section of TheSamba.com Pretty much largest aircooled site.
In reply to Tim Suddard :
If KCW has some, I can deliver to Vegas next week. I'll be driving right past their shop on Thursday.
In reply to RoddyMac17 :
You flip the ring gear if you're changing from the stock rear engine configuration to a mid-engine one because turning the transmission around creates a one forward/four reverse gear situation.
Here's the Elva build thread, btw:
https://classicmotorsports.com/project-cars/1962-elva-mk-vi/
Is that just to keep the input shaft above the output, as in the "stock" location? If you were to invert the gearbox (flip it upside down) then turn it front to back, wouldn't that keep it as 4 forward and 1 reverse and not need to flip the ring gear?
Flipped you will run on the wrong side of the ring, think any 4x4 front end that is not high pinion. Flipping also could create some oiling issues.
RoddyMac17 said:You flip the ring gear if you're changing from the stock rear engine configuration to a mid-engine one because turning the transmission around creates a one forward/four reverse gear situation.
Correct, but doing that also changes the height of the engine from the ground, too. You may or may not want that.
Rigante said:Audi 01E comes in 2wd and no flipping required
I need one for my Opel.
so why use an old trans that needs modification when modern VW audi 2wd stuff would work?
In reply to Rigante :
Because they very specifically won't work for what I have planned. Cost, weight, complexity, all of that is not something I want for this project.
I still need to sit down and check gear ratios and all, but things are looking good.
In reply to MuSTANK :
Nice. I should be able to use that to figure out what I want to do. Of course, there might be a possibility I won't be able to use the ideal trans for it.
That's really cool. Looks like someone took a drill to a solid axle backing plate. Is it a aftermarket solution or some modified stock pieces? Looks aluminum so should be fun If you have to recreate all the holes.
A swing axle Type 1 transmission can be run upsidedown. A lot of mid-engine rails go about it that way. I've been out of the ACVW game a while and forget why they don't use the IRS transmissions upsidedown.
