12 13 14
Alfaromeoguy
Alfaromeoguy HalfDork
9/18/24 1:24 p.m.
I have the exhaust collector tubing contours correct now, now to cut the steel and weld all the parts together , 1.825 tubing
Alfaromeoguy
9/20/24 8:40 p.m.
Making the mounts/ stencil for the new exhaust collector tubing
Alfaromeoguy
9/20/24 8:41 p.m.
The two post will help me keep the c-t-c spacing correct
Alfaromeoguy
9/21/24 4:24 p.m.
Now to slowly trim the exhaust tubing to blend together
Piguin
Piguin Reader
9/21/24 4:52 p.m.
Love the step by step process for the exhaust.
Helps people like me get a bit more insight.
Alfaromeoguy
9/21/24 7:49 p.m.
Tack welded and added a extension. Still need to trim and merge the lower pipes together
Alfaromeoguy
9/27/24 7:19 p.m.
Interesting day, while working on my spider exhaust,I had these 2 'experts' walk up to me and start telling me how to do the job I was working on, they both told me they were mgb experts, so I decided to mess with these 2 Arab experts, so I started quizzing them on my "MGB 🤣🤣🤣' after a while I told them it was a alfa romeo, not a MGB, but they kept insisting that they were MGB experts and my car was a British car, so I found my DMV paperwork and opened the driver's door to show them it was a alfa Romeo,made in Italy,.. then they started to double talk and make up excuses. I told them to piss off, all these experts, wow
Piguin
Piguin Reader
9/28/24 4:54 a.m.
At least they didn't try to explain to you how Alfa Romeo stole the MGB blueprints because that was OBVIOUSLY an MGB, engine and all cool
Alfaromeoguy
10/8/24 6:47 p.m.
Spacers between the disk and the face of the hub,2mm, will not affect the parking brake . The button Allen screws were rubbing on the brake backing plate
Alfaromeoguy
10/14/24 6:51 p.m.
Kinda rat rod, looking now, but it will have new paint next spring. But the brakes are finished, I have new front rotors at home. These are just the old ones, for test fitting
Alfaromeoguy
10/31/24 9:38 p.m.
take 3 on the collector below the header.mot much room to work with, engine,body shell, steering system, so this time much slower on the cuts,and trim to, fit slow,and a lot of tape
Piguin
Piguin Reader
11/1/24 1:18 a.m.
Third time is the charm.
Alfaromeoguy
11/9/24 7:36 p.m.
Piguin,I hope you are right,still must cut out the flange, but lots of blue tape and sharpies,and very careful cuts, and sanding disk, good enough for tack welds. Very close fits in the merge
Alfaromeoguy
11/9/24 7:36 p.m.
Alfaromeoguy
11/10/24 12:49 a.m.
Without the blue tape on the tubes
Alfaromeoguy
11/10/24 9:07 p.m.
Flange is drilled for exhaust tubes and bolts after setting the tubes in at the angle and dept I need,to clear the engine and body shell,o woll mark and spot weld,if it works out good, i will bolt this to an aluminum block to weld,the aluminum block will work as a heat sink to keep the flange from warping
Piguin
Piguin Reader
11/11/24 2:41 a.m.
Looking good so far.
Don't prove me wrong now!
Alfaromeoguy
11/19/24 11:10 p.m.
spot welded and sanded down, clean. for final welds.. the soapstone marks are for me, so i can see the weld area, when i am welding.
Alfaromeoguy
2/17/25 6:01 p.m.
In reply to Alfaromeoguy :
very very little room to work with so these did not work.. i have a differnt idea..
Alfaromeoguy
2/17/25 6:04 p.m.
last rear brake and disk on the car.. strange thou.. a porsche boxster brake master clys is only is only 55 to 75 $ the reservior is double or triple the cost of the master cly itself..167-230$
Alfaromeoguy
2/17/25 10:05 p.m.
cleaning out the fuel tank..then xolder the pate on top of the tank, kinda of a bess now.. but have practicing how to solder..
12 13 14
bVpmOZVeEu4LZkFACJnNQJoIo0uumDxwRpTMy642cUzsT1FoaXtY3P8TCfQXV3eC
