First bet is internal disintegration of fuel lines, some of which are post filter, but open them up too.
TurnerX19 said:First bet is internal disintegration of fuel lines, some of which are post filter, but open them up too.
It certainly seems like that could be it, but I replaced all the fuel lines just a few years ago. The only one I'm not 100% sure was replaced was the elbow at the feed from the fuel tank. It's a larger diameter so it's possible I didn't have the right line but I just can't remember.
never opened a fuel filter before, so not sure how to read it but it seems like there a lot of junk in here.
That looks like the stuff that accumulates in my X1/9 tank when ever the car spends a few years sitting. I have not yet had it get through a filter. Is all the dust on the outside? If the crud is from both sides of the paper you need to back flush everything and it is your culprit. If the outlet side was clean you may have more trouble downstream.
TurnerX19 said:That looks like the stuff that accumulates in my X1/9 tank when ever the car spends a few years sitting. I have not yet had it get through a filter. Is all the dust on the outside? If the crud is from both sides of the paper you need to back flush everything and it is your culprit. If the outlet side was clean you may have more trouble downstream.
The crud seems to all be on the outside, though there is a lot more than I was expecting. There's only like 20-30 hours of run time on this filter since new haha.
I had to remove the tank and clean it twice in the time I ran my silver car. I had sat a decade at least when I first bought, and the striations in the tank looked like it was run 20 miles once per year. All washed into a container and evaporated into what you have in the filter. There is a soldered in fine brass mesh pre filter in the tank too.
Very similar stuff in the injector filters.
also, some chunks of rubber came out of the lines, but I'm unsure if those are from removing the fuel injectors just now. The barbs may have cut up the lines a bit.
so, I've ordered new injector filter baskets, and I'll order a bunch of fuel filters and change like every tank of fuel or something. They're filter sure seemed to catch a lot of the crud, but maybe it just got full.
I made a thread on the main page to see if I can up my fuel filter game:
https://grassrootsmotorsports.com/forum/grm/is-a-fuel-filter-a-fuel-filter/278104/page1/
new filter baskets in the injectors, and I used my cheapo Amazon injector tester tool to ensure they all are working and spraying a similar amount of fuel.
Put it all back together and we're back in action, running great! Current plan is to just keep replacing the fuel filter like every tank of gas or two for a while. If I keep plugging injectors I'll re-evaluate.
