4 5 6 7 8
JohnnyBquick
JohnnyBquick Reader
2/4/15 11:08 p.m.
The mold for my new engine cover has been started using the original cover to make the mold from. The new one won't have louvers. The plan is to have a open hole instead and have it trimmed in polished stainless with stainless in the center.
JohnnyBquick
JohnnyBquick Reader
2/4/15 11:14 p.m.
Built this engine for my GLHS, but decided its been on the shelf long enough. Its going to get finished and put in the GTP....along with a new clutch and trans with a Quaife limited slip.
JohnnyBquick
JohnnyBquick Reader
3/3/15 11:05 p.m.
Engine cover is made. Now designing the "vent" hole and building it. Before I cut the hole.
[URL=http://s1312.photobucket.com/user/glhs289/media/enginecover4_zps2vwpqxev.jpg.html][/URL]
JohnnyBquick
JohnnyBquick Reader
3/3/15 11:10 p.m.
Also learning how to and doing some interior work. [URL=http://s1312.photobucket.com/user/glhs289/media/IMG_1_zps4zaxgizf.jpg.html][/URL]
Javelin
Javelin MegaDork
3/3/15 11:25 p.m.
Are you going to bring it out to an autocross this year?
JohnnyBquick
JohnnyBquick Reader
3/4/15 11:02 a.m.
I am sure going to try!
JohnnyBquick
JohnnyBquick Reader
3/9/15 11:41 a.m.
Got the inside panels done and installed. Used a fold out cup holder as part of the project. [URL=http://s1312.photobucket.com/user/glhs289/media/interior3_zpsgazynxjg.jpg.html][/URL] [URL=http://s1312.photobucket.com/user/glhs289/media/interior2_zpsdymdrta3.jpg.html][/URL] [URL=http://s1312.photobucket.com/user/glhs289/media/interior1_zpstkgnbjox.jpg.html][/URL]
bgkast
bgkast UltraDork
3/9/15 2:58 p.m.
Looks factory. Nice job.
JohnnyBquick
JohnnyBquick Reader
3/10/15 4:54 p.m.
Engine cover is painted.
Dusterbd13
Dusterbd13 SuperDork
3/10/15 5:46 p.m.
Where did you get the fold out cupholder? May be what im looking for. ..
Junkyard_Dog
Junkyard_Dog SuperDork
3/10/15 7:27 p.m.
Dusterbd13 wrote: Where did you get the fold out cupholder? May be what im looking for. ..
Not sure where they came from originally (aftermarket?) but I always find them in 80s Volvos.
turboswede
turboswede MegaDork
3/11/15 8:32 a.m.
My 951 has one as well (even had the Porsche crest for extra cheeze, heh). Only it was broken (they aren't terribly strong, so avoid the extra large sodas). Bought a new generic one Amazon for like $2. I did see a stainless steel version for Marine use that was about $20, but I didn't want the shiny look in my car.
Stainless: http://www.amazon.com/Amarine-made-Stainless-Adjustable-Folding-Holders/dp/B0097YH972/ref=sr_1_3?ie=UTF8&qid=1426080532
Plastic: http://www.amazon.com/Universal-Folding-Adjustable-Drink-Holder/dp/B00CSYUXTE/ref=sr_1_5?ie=UTF8&qid=1426080574
JohnnyBquick
JohnnyBquick Reader
3/11/15 12:40 p.m.
Yes, I found the cup holders on-line. Think mine was from amazon or eBay. I saw the steel ones, but bought plastic to see if they even worked first. I liked the grey. If these become an issue, I'll get the metal ones.
JohnnyBquick
JohnnyBquick Reader
3/11/15 12:42 p.m.
Finished the install of my new VDO speedometer that runs on gps. It lights up but doesn't work. I need to recheck my wiring......
JohnnyBquick
JohnnyBquick Reader
3/22/15 8:08 p.m.
Got the speedo to work, it was just a ground.
JohnnyBquick
JohnnyBquick Reader
3/22/15 8:22 p.m.
Continued on the vent today for the Consulier GTP engine cover. 9. Made a upper and lower piece from 3/4" plywood. Cut them apart at an angle with a jig saw to the size I wanted. Sort of a male/female now that will mate together to form the mesh. Used a upper to press over the lower with the stainless screen/mesh in the center. This hopefully will bend the screen to the shape I need. 10. The goal was to then use screws to press the upper down. Used the hammer hitting the upper wood piece, then tighten the screws a little, then hammer, then tighten. 11. After tightening as much as I could, I took all the screws out. ...and pulled the top piece of wood off. 12. Looks like it worked. 13. Set the trip piece on and marked where it needed trimmed. 14. Cutting the screen 15. Set it all on, looks like it will work. Will get some stainless bolts tomorrow and assemble it on the engine cover.
bgkast
bgkast UltraDork
3/22/15 8:25 p.m.
May I ask why you used a gps speedometer in place of one of the programmable units that you calibrate to the VSS?
I ask because I'm looking at both types for my build.
JohnnyBquick
JohnnyBquick Reader
3/22/15 8:35 p.m.
Just thought it would be easier. It works but not sure it is at the right calibration. Seems off.
turboswede
turboswede MegaDork
3/22/15 9:48 p.m.
The factory VSS for that generation of Turbo-Dodge wasn't very robust. The later Neon's (like yours) were better.
JohnnyBquick
JohnnyBquick Reader
3/25/15 8:49 p.m.
Looks pretty good. Test drive...engine noise is much less with the engine cover on.
bgkast
bgkast UltraDork
3/25/15 10:05 p.m.
Nice
Petrolburner
Petrolburner HalfDork
3/26/15 3:23 p.m.
That thing is so cool, nice work.
JohnnyBquick
JohnnyBquick Reader
3/26/15 11:39 p.m.
Mock up on the air deflector I am building.
JohnnyBquick
JohnnyBquick Reader
3/27/15 10:19 p.m.
Yarn tuft test before the air deflector.
https://www.youtube.com/watch?v=5yLmW2NQ0Yo
JohnnyBquick
JohnnyBquick Reader
3/28/15 9:06 p.m.
Got it made, now disassemble it and prep for paint.
4 5 6 7 8
blLxOCwNm8AQqIqq8epGcCbwEmtfDuPSL1GCfr2ermVH1nfBeJ3ed5K3aZBBzO1E
