SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) PowerDork
4/9/23 10:25 p.m.
Finished the zig-zag through the front X:
Next the corkscrew through the rear X.
4/9/23 10:40 p.m.
In reply to SkinnyG (Forum Supporter) :
Nice work!
4/10/23 8:23 p.m.
  First, we need to go UP from the unmuffler:
Then I'll need a 6" straight to connect to the left side of this, up over the frame, and into the fenderwell ahead of the wheel. Man, this took forever.
Kendall Frederick
Kendall Frederick New Reader
4/10/23 8:27 p.m.
How's the solar flux working for you?  I have a jar somewhere, but never really used it much.  What do you mix it with?
Mr_Asa
Mr_Asa UltimaDork
4/10/23 8:43 p.m.
We used it fairly regularly on the FSAE team.  Did a good job.  Mixed with water, I think?  Been a couple years since I've messed with it though
Kendall Frederick
4/10/23 9:13 p.m.
I tried it with water a time or two, but did not feel like it mixed well.  Google (well, Harris, the mfr) says mix with alcohol and that methanol is preferred.  I would expect regular rubbing alcohol would work fine but haven't tried it.
Mr_Asa
Mr_Asa UltimaDork
4/10/23 9:16 p.m.
In reply to Kendall Frederick :
Maybe it was alcohol.  Like I said, it was a while back.
4/10/23 9:26 p.m.
I bought the Solar Flux years ago, because it seemed more convenient/cost-effective than having another Argon tank and reg.  It works well, I mix it with Methyl Hydrate at the moment, because that's what I have on hand. The tin recommends Methanol.  I had recently used it on the outside of tubing where I was welding on the inside.
All of these welds were done with back-gassing off a second regulator Tee'd off my tank, I just haven't put the tin away.
Kendall Frederick
4/10/23 9:42 p.m.
Thanks for the info.  I need to put a tee in after the flow meter where I can back purge, but I am planning some stainless sheetmetal work that could probably benefit from the flux.  Now I just gotta find it..
4/10/23 9:49 p.m.
I would T and run a second reg.  I backflow only around 5cfh, and you need a bit of time for it to fill up the space.
4/14/23 8:34 p.m.
Christmas!
HP Tuners, AEM Wideband, Spider Caps, Plug Wires, AND a Classic Instruments panel all arrived today!
I'm enjoying the selling of my '77
4/14/23 9:40 p.m.
Spider Caps:
wheelsmithy (Joe-with-an-L)
4/15/23 8:14 a.m.
Outstanding!
4/16/23 12:10 a.m.
Definitely need another band clamp - there is no way this psycho corkscrew of a tailpipe can be one piece and installable.
obsolete
obsolete HalfDork
4/16/23 1:00 a.m.
Are those not the same thing?
eastpark
eastpark HalfDork
4/16/23 9:28 a.m.
Spider Caps:
Cool! What are your first impressions of these? I'm thinking they'd look good on the winter steelies for the wife's car.
4/16/23 11:14 a.m.
I have no idea.  It's an alcohol.
4/16/23 11:15 a.m.
Spider Caps:
They're pretty.  I haven't mounted them yet, so I don't know how annoying they will become.  For winters, I'd definitely use never-seize on the wee screws that hold the caps to the mounting plate. I'd hate to try and remove them when they're seized.
Hmmm..... Thinking....  I guess one could just drill and tap holes in the wheel center, and not use the backing plate at all.....
4/16/23 10:03 p.m.
4/22/23 1:34 a.m.
Line Lock arrived. Good, as I'm going to be doing the brake lines soon.  More of a novelty than required, but I've never had one before, and kinda want one.
4/28/23 10:04 p.m.
And fabricated an air filter elbow as well:
TurboFource
TurboFource HalfDork
4/29/23 7:28 a.m.
Nice work!
I just use rubbing alcohol with the Solar Flux
4/29/23 11:28 p.m.
I did have to cut a bit off to actually fit the filter.  Just.
5/1/23 12:24 a.m.
Back on the fuel filler, with the vent to make filling much easier:
5/1/23 9:12 a.m.
i have mentioned this before, but i'll say it again: i'm a huge fan of your work.
ewElIIbV6z6BWpqgt9IBONKctcp0adxjuqkNfjSvOC8JXUpdDG4DOYYHWnWMa60Z
