GVX19
GVX19 New Reader
11/27/09 9:39 a.m.
Can anyone help me fix the idle speed?
The car idles at 2k in park. I need it to run closer to 1k.
HELP!
Thanks.
AngryCorvair
AngryCorvair SuperDork
11/27/09 11:05 a.m.
i got nothing for you, but i know you can figure it out. if it's not throwing a code, look for vacuum leaks or binding in the linkage/cable.
many years ago, you said to me, "you know, that tire would already be off the ground if your shock wasn't broke in two." and you were right.
benzbaron
benzbaron Reader
11/27/09 2:27 p.m.
+1 on vacuum. The vacuum system on these cars is a real pain. Check the connection and vacuum tubes for leaks, I hear people do it with ether or carb cleaner and see if the idle changes when the volatile solvent is sprayed on a fitting, meaning you have a leak.
Good luck!
r2DSdjd28aoNYscHgAjyEDvhMqChzG9VfxnQsnmjCfo6HmtBSOCcUQexvlO46l6k
