bravenrace
bravenrace MegaDork
4/15/17 6:00 a.m.
I have a friend that is looking for 175/70-13 tires for vintage racing. He's not concerned with winning, he just wants an affordable tire he can use for this purpose. Anybody know of a source?
LanEvo
LanEvo Reader
4/15/17 6:25 a.m.
I've only done some vintage racing with a group in Canada (VARAC), so I can't say for sure. But my understanding is most vintage racing groups will specify which tires you can run, especially in "historic" classes. He may have to use something like the Hoosier TD, which are treaded bias-ply slicks.
If he's allowed to run non-DOT tires, he can look into circle track slicks from Hoosier or American Racer. I started a thread about this a couple of days ago. In the sizes I would run, they're much cheaper than DOT-R options.
LanEvo
LanEvo Reader
4/15/17 6:29 a.m.
Hoosier TD-S:
https://www.hoosiermidatlantic.com/product.cfm?invKey=63305
13" options from American Racer:
http://www.americanraceronline.com/tires/midget-mini-stock-asphalt/
Knurled
Knurled MegaDork
4/15/17 7:10 a.m.
Check eBay for used tires.
Seriously, I'm not kidding. I've found a couple stores there with some remarkable 13" lightly-used selections.
SyntheticBlinkerFluid
4/15/17 4:34 p.m.
So I know you said 175's but the next nearest size that Tire Rack has as a performance tire are a 205/60-13. There's actually a few.
My dad ran 205s on the stock 13x5.5 Corvair wheels when he raced and autocrossed.
https://m.tirerack.com/tires/TireResultsServlet?tab=ALL&width=205%2F&ratio=60&diameter=13&rearWidth=255%2F&rearRatio=40&rearDiameter=17&zipCode=#0
Ovid_and_Flem
Ovid_and_Flem HalfDork
4/15/17 5:17 p.m.
In reply to bravenrace:
What in the world is he racing that needs a 175 70-13?
bravenrace
bravenrace MegaDork
4/15/17 5:36 p.m.
In reply to Ovid_and_Flem:
Fiat 850
4/15/17 6:12 p.m.
After doing a little research, it looks like Avon is the only one with a 175/70-13 performance tire, if you want to call this a performance tire.
http://www.avonmotorsport.com/historic/historic/cr6zz
Tom1200
Tom1200 HalfDork
4/15/17 6:49 p.m.
First up he has two good choices for vintage tires; Hoosier Street TDs in 185/60-13 they are a very short tire 20.6 tall with 7" section width. They'll likely fit under the fenders of an 850. The other tire is Avon ACB 9, these are taller than the Hoosiers but have a 6" section width.
The Avons do not have the ultimate grip of the Hooiser (it's close) they also have a taller sidewall and are huge fun. They have a good bit of windup so you can hang the car out and look like a total hero. I tried a used set a couple of years back and the fun factor was big. I think the size is 6.0 x 22 x 13
Both of the aforementioned tires are bia ply so he'll need to set the car up accordingly.
When I get used tires I get them from John Berget, usually $50-60 per tire.
For the past few years I've been buying new tires, the Hoosier TDs are $180 a piece.
Ovid_and_Flem
4/15/17 7:04 p.m.
bravenrace wrote: In reply to Ovid_and_Flem: Fiat 850
. That explains it. I had an 8:50 in college and had a ball with that little car when it was running
37kY8F0WsBKS9UsKc48erzAGAmxE5CY9RgJDhS2GrVF7662B40dmBokqgHyVtHs3
